- Jan 28, 2008
- 10,321
- 18,833
- Renalt burstner
- 7 years campers before that
The two supplies are separate. One is a permanent live from the habitation battery, for the control electronics. The other is from the alternator/starter battery for the 12V heater element.with an AES fridge do you still need a fridge relay or does the d+ signal to the fridge allow it to chose when to use the 12v supply i appear to have two 12v pairs and a d + so assume both 12vs are permanent live
I need to add that if there's no relay, and you turn it on 12V manually, it won't turn off when the engine stops, and will stay on until the starter battery is flat. If there's a relay, it will cut off when the engine stops.You don't actually need a relay if you only ever run the 12V element from the alternator/starter battery. But if you ever want to run it from the hab battery a relay or manual switch is needed.
