Looks like the common consensus is your regulator is banjaxed ! Best of luck going forward. (I also think your battery capacity is not good and you will know for certain soon enough if I am right !).
The O.P.did say the regulator was working correctly when first connected, so unlikely to be as a result of what you suggest.as lenny HB has asked when you fitted the new regulator did you connect the battery connections to the terminals on the regulator before you then connected the solar panel wires because it is very important that the connections are made in this order. That is, battery to regulator first , If you did not or you not sure try disconnecting the regulator and reconnecting as described.
If the connection was made in the wrong order when not in sunlight is it possible that it would show battery voltage at first and then increase unregulated , when the sun came out, as the regulator had not been set to 12 volt instead of 24 volt ? I also think it could be a faulty regulator but perhaps this could happen ?The O.P.did say the regulator was working correctly when first connected, so unlikely to be as a result of what you suggest.
The important part is this...It was fitted by Conrad Anderson for the original owner. I have taken on the truck and the fault only seems to raise its ugly head during the day time and not at night? Making me believe the solar controller being at fault.If the connection was made in the wrong order when not in sunlight is it possible that it would show battery voltage at first and then increase unregulated , when the sun came out, as the regulator had not been set to 12 volt instead of 24 volt ? I also think it could be a faulty regulator but perhaps this could happen ?
I think your clutching at straws to be honest ! Hopefully, the O.P. will provide some feedback after fitting the replacement regulator and put this thread to bed.If the connection was made in the wrong order when not in sunlight is it possible that it would show battery voltage at first and then increase unregulated , when the sun came out, as the regulator had not been set to 12 volt instead of 24 volt ? I also think it could be a faulty regulator but perhaps this could happen ?
The question is not where you connected the wires but in Which order you connected them.The one I fitted was a direct replacement with only four used connections . Really all self explanatory as regards fitting. It was a pos and neg from the solar panel into its corresponding ports highlighted and a pos and neg from the battery bank fitted by Conrad Anderson from the Bridge gubbins they have fitted.
If the system is switched off entirely and by that I mean Isolated entirely...What difference would it make ? If the battery bank is connected first (Just my thought here as its the means to accept a load and ready and waiting )...If I then connect the solar panel wires as I would have thought is correct..neutral one first and then the pos one....What should I have done differently or what could be done differently ?The question is not where you connected the wires but in Which order you connected them.
If you did it that order it is OK.If the system is switched off entirely and by that I mean Isolated entirely...What difference would it make ? If the battery bank is connected first (Just my thought here as its the means to accept a load and ready and waiting )...If I then connect the solar panel wires as I would have thought is correct..neutral one first and then the pos one....What should I have done differently or what could be done differently ?
Intrigued?
Kev
