- Feb 2, 2015
- 2,323
- 7,344
- Nowt!
- Learning to appreciate what time we have left
Hi Guys.
Swapped a solar controller recently because the one fitted to the Mh was causing the Sargent Panel to shut down and turn off the 12v electrics across the truck!
I replaced it for a German unit but I seem to be having the same fault? I checked the input from the solar panel when connected up and on the one controller it was showing 18v! When I replaced it with the German one..14.7 volts and all was ok. Until Yesterday? Same fault exactly ..18v at the controller going into the battery bank? Yet there is no reason for it to be at fault as far as I can see? Any advice please?
If i disconnect the solar Controller.......the system charges well with the Sargent system and all functions as it should do.
The battery bank is 2 x 100 Wet acid (Sealed) Numax batteries and a starter . There is a special "Bridge system" installed to aid the Starter Generator to sense low battery power and to fire up and charge the low battery when needed. Makes it very self sufficient and rarely need to be on EHU to be honest.
Just struggling with the soalr side of things at the moment if any one can help at all?
The original controller was a EP solar LS1024B (Chines I believe? But reputable) There is no digital screen on this type. A remote one is available though.
The one fitted is a German equivalent as I wanted a easy fit and what I thought was the right one?
The 2 leds Battery and Solar flash rapidly when a over charge fault is detected. This is where I am currently again!
Regards Kev
Regards Kev
