Advice please - found a potential motorhome (1 Viewer)
In the Pink
84
85
Surrey/Sussex
Hymer B564
Complete Novice
Good morning Funsters
I am looking to buy a Hymer Exsis SK and they are few and far between. I have found one that I am potentially going to view in Dorset.
It is a 2005, Fiat 2.0 litre Jtd, 32000kgs GVW with 43,000 miles on the clock.
From previous posts on the forum the advice is don't worry about high mileage, that's what they are built for, better the motorhome is used and not sat around.
If the mileage is genuine, should I be worried it has not been used that much??
The seller says
'We are the 2nd owners and have had the Exsis since 2010. Most years we go away at least once for approx 4 weeks (mostly to France) and then have the occasional short break'
Your thoughts/advice would be appreciated.
Thank you and have a good day
MikeD
3,936
3,697
London
IH PVC
Since 2012
Take a damp meter and walk away if any readings are over 20%
Check all the paperwork especially Habitation checks.
If you do not understand how a motorhome works or never had one before - take someone who does. They are complicated bits of kit and some replacement parts are eye-watering expensive.
Low or high mileage not really a problem if it has been cared for and has regular serving. Have they got all the service invoices since 2010. Don't rely on stamps in the book.
I would post the advert and let people comment, someone might know the van.
Happy hunting (y)
7,240
20,128
Barnard Castle, UK
Concorde Concerto
Check service history, cam belt change, does it run well? Do you know much about engines, mechanics etc or can you take someone with you who does?
some on here will say unless it's done 10 thousand miles a year then walk away, I disagree, it may still have been well looked after with low mileage.
mfw
Banned
Sep 16, 2017
1,224
508
Worthing
2.0 ltr jtd engine may be slow and underpowered especially on hills depends really if you are in a rush to get to places or happy to take day by day.
If it looks and smells ok ( damp smells ) pay out to get more checks done which will give peace of mind and some sort of insurance if done professionally
In the Pink
In the Pink
84
85
Surrey/Sussex
Hymer B564
Complete Novice
Thanks guys for your prompt responses...
I know nothing about motorhomes so if it is a potential purchase I will be looking for a mechanic to carry out an inspection.
@mfw I was wondering whether 2.0 litre would be sufficient. Ideally looking for the 2.3 litre version but hard to find.
I took advice from funsters and hired a van, it was a cChausson on Ford 2.0 litre engine and was a heap of s*** and laboured up any hill.
But, it was a hire van, that had clearly been worked hard and is a lot bigger than the Hymer Exsis.
Thanks again for the sound advice. As everyone says, joining the forum is the best £15 I have spent
mfw
Banned
Sep 16, 2017
1,224
508
Worthing
Never had a 2.0ltr but my 2.8 jtd can and does struggle on some steep hills unless i let it rev high in a lower gear - i tend to just let it rev to 2500 it can rev higher but change gear and power drops off so i just let my van have an easy life but i'm in no rush
TerryL
6,184
8,186
North East
Low Profile
@In the Pink With all the info you've now gleaned go have a look at it. Try not to listen to the vendors who will of course will be extolling it's virtues and overlooking it' faults. Make a few notes then come away and post again with your findings. As you've found out you'll get a lot more advice - okay some of it will be cinflicted but you should then have a much better idea if "it's the one"!
Good luck!
irnbru
13,514
31,141
Glasgow
Benimar 264
11 yrs
It looks a reasonably well maintained van. Check the date on the tyres. Good luck.
In the Pink
In the Pink
84
85
Surrey/Sussex
Hymer B564
Complete Novice
So after the readings Jim's book again, I asked the seller a number of questions - his answers are in bold text.
After all I have learned from you good people I am surprised and concerned that nohabitation check or damp check has been carried out by the owner in 8 years of ownership!??
How many leisure batteries does it have and how old are they? One. Replaced in April 2015
Is a solar panel fitted? No
When was the last proper habitation check carried out? I never felt the need for a habitation check. Last one was August 2010 prior to my purchase.
When was the last damp test carried out?I never felt the need for a damp check. Last one was August 2010 prior to my purchase.
Has it ever been in an accident? No
Is there a full service history with receipts? I have Receipts for all (most - I can’t guarantee that I haven’t mislaid some ) work since I purchased it in 2010.
How old are the tyres? April 2015
Date of last service? July 2018
Date cam belt was last changed? June 2013
Date gas (boiler/fridge)last checked/serviced? Not known
Are there gas/Lpg detectors fitted? No
Do you have the manuals for the equipment? Yes
So what do you guys think?
Any further advice/guidance appreciated.
Thank you once again
7,240
20,128
Barnard Castle, UK
Concorde Concerto
That's really difficult as a lot of people on here don't have damp or hab checks. You need to take a damp meter and check for yourself the full condition of the van, or take someone with you who knows.
9,785
20,150
Newcastle under Lyme
Hymer B544 A Class
Since 2015
My Hymer is a 2003 B544, I`ve had it coming up to four years and never felt the need for a hab check.
I check myself regularly for anything untoward and mostly do my own maintenance. I`ve learned how to remove the fridge and service it. Mostly from friendly advice on FUN.
The main thing now I`m not sure about is if the Truma blown air boiler needs any servicing / maintenence. It`s working fine so my instinct tells me if it`s not broke, don`t fix it.
Writing this has prompted me to investigate further so I`ll post the question.
PS I just remembered, I did pay for a hab check before I bought it so I think the advice would be for you to do the same, or take someone who knows how to work a damp meter
Edit - have you posted a link to the ad ? would be useful for others to give it a scan over for anything that`s obvious to experienced motorhomers
In the Pink
In the Pink
84
85
Surrey/Sussex
Hymer B564
Complete Novice
Thanks guys....
There's no 'ad' as such. I posted a 'wanted ad' on the Hymer Exsis forum and this guy came forward saying they are thinking of selling and gave me the basic details. It transpires he is not committed to selling until he finds a suitable replacement and I understand he has a couple to view.
43,329
49,443
My main concern from your list of questions and answers is the cam belt.
At 5 years since last renewal it's definately due/overdue for renewal.
Cost of replacement could be between £300 & £400.
If it isn't replaced there's a very real chance it can fail with catastrophic consequences which could increase the repair bill by up to a thousand pounds.
£400 or £1400.......your choice.
10,116
18,382
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
cam belt five years old is a bargaining point i would be worried if gross vehicle weight at 3200kg will give you enough payload possibly ok for a solo traveler
MikeD
3,936
3,697
London
IH PVC
Since 2012
For me answering the questions like this is a person who bought and has run the motorhome on a shoestring.
They have never spent a penny on anything unless it inconvenienced them.
I suspect you will find major items that do not work properly and almost certainly damp issues.
TerryL
6,184
8,186
North East
Low Profile
Okay, you've told us what he said and I don't think there's anything suspicious there, other than what others have posted.
So what were your impressions? Did you like the look of it? Did it feel okay - even if you know very little about things you often get a "feel" for them. More to the point, do you think you could live in it?
We can only offer suggestions, in the end it's your money you're spending. If you still want to go ahead and think it's worth it arrange to have a habitation check done by a professional who knows about motorhomes, the AA or RAC are not experts in this case although they will check the mechanicals. Paying £150 now could give you peace of mind - or save you thousands of pounds.
2,784
2,128
West Sussex, UK
Hymer B680 Starline
Long term a few years now.
Where is the van ?
At the moment im in west Sussex on the south coast if its anywhere near i would be more than willing to give it a once over for you.
Same goes for any funster looking down this way.
9,545
32,087
sleights
c class
You have not told us one of the main deciders the price!!. If its low it might be there would be a bit left over for any repairs sounds good to me that someone has had it for 10 years not getting rid after a couple ( if there are problems) also just 2 owners. I would get a hab check after negotiating a price dependant on it passing if you decide it looks like the one for you.
In the Pink
In the Pink
84
85
Surrey/Sussex
Hymer B564
Complete Novice
@wigster
Thank you for the kind offer but the van is in Dorchester, Dorset.
@thewho @TerryL
Thanks guys.
It's £24k which compared to other SK's I've seen is overpriced, especially for a private sale. I'm going with my head and not my heart and have decided not to buy this one.
Thanks everyone for all your input, it's really appreciated and valuable, especially to someone like me. I know nothing about motorhomes and this will be my first purchase!!
Still looking for a RHD Hymer SK if anyone is thinking of selling
mfw
Banned
Sep 16, 2017
1,224
508
Worthing
Old motorhomes 10yr old + have huge variations on price for same/similar models it is very much buyer beware
440
1,232
Bridport Dorset
Swift Kontiki 655
Trailer tent for 10 years Motorhome since 2018
Suggest looking on the DVLA / gov vehicle tax web site and inputting the van reg (if you have it) there you will find the MOT history including any advisories and previous failures??
