RFS
- Apr 30, 2013
- 122
- 294
- A Class
- Just on my second van but still I'm a newbie
Hi all
I'm hoping that you might be able to offer some advice.
I presently only have one leisure battery (it's an 80ah) in my Master based MH.
I have 2 X 100w solar panels and would like to have 2 leisure batteries as EHU isn't used that much. I have updated my weight from 3500 to 4200 so I have the payload.
There is room in my battery box for 2 batteries (see image) and the Banner Energy will fit nicely.
I think it's something I can do myself, the battery posts are the same size so I will need to get 2 new straps to connect the batteries in series. Do I connect the solar panel outputs from the regulator to just one of the batteries (as they are connected now)?
I also want to fit a battery monitor which was recommended on here and is quite cheap off that well known auction site.
A question I have is (see image) how do I connect the shunt. I know it needs to go across the load, however, the battery as connected at the moment has 3 outputs (all fused) from it so I presume all these have to connect to the shunt to ensure I get an accurate reading? Can I simply cut these in-line join
them and insert the shunt? I can see that the ground side connects directly to one side of the shunt but I want to make sure that I properly capture the load, otherwise I might as well forget the monitor.
Hope the images have uploaded.
Many thanks for any advice.
R
R
