Advice needed regarding ACE Airstream 680FB
Discussion in 'Motorhome Chat' started by DonF, Sep 12, 2017.
  1. DonF
    DonF Funster
    Jun 18, 2016
    12
    Dumbarton
    Ratings:
    +1
    Can anyone please help inside the water tank access cap there is a drain for want of a better word bung, I have been in touch with swift ,marques and a few others but cannot get the proper bung the problem is it has a small slot leading out from the circular part therefore when you use a circular bung it leaks from the small slot.
    Can anyone help please
    Regards
    Don
  2. mike mcglynn
    mike mcglynn Funster Life Member
    Jan 6, 2008
    1,835
    St. Helens MERSEYSIDE
    Ratings:
    +13,570
    Hi, could you try a universal plug which you buy from a diy place should fit all types of plugholes .
  3. jezport
    jezport Funster
    Oct 29, 2008
    2,652
    West Yorkshire
    Ratings:
    +2,552
    Put up a photo as it may prompt a better reply
  4. DonF
    DonF Funster
    Jun 18, 2016
    12
    Dumbarton
    Ratings:
    +1
    Tried different plugs all the same just tapered the problem is the little notch off the circular bit which to me it's like inserting plug then quarter turn to lock it in position
    Tried taking picture but too dark
    Regards
    Don
  5. TerryL
    TerryL Funster Life Member
    Mar 5, 2010
    2,381
    North East
    Ratings:
    +2,958
    Our Bolero is all but identical and our freshwater tank drain is, as you say, a rubber bung. But it's round, no slot in it so looks like someone may have made some sort of mod but I cannot imagine what. That's probably why dealers etc can't help.
    No doubt someone (even me) could come up with a solution, but, again, a photo would help. Could you "modify" the bung? Thinks; a wine bottle cork to experiment with?
    (Edit) posts crossed.
  6. DonF
    DonF Funster
    Jun 18, 2016
    12
    Dumbarton
    Ratings:
    +1
    Hi Terry many thanks for response tried taking pictures ended up too dark the leak is coming from the keyed bit was even trying to source another tank but was told because of its shape (tank) cannot find one I know it's a drastic measure but what other choice unless I find a breakers yard
  7. Stretto Boy
    Stretto Boy Funster Life Member
    Nov 6, 2016
    1,270
    Leicestershire
    Ratings:
    +14,751
    Could you seal it with some sort of waterproof mastic? Even if you cannot then remove the bung, you could still drain the tank by running the taps so that the water goes into the grey tank and then empty that. I'm not much of a handyman, so I expect this suggestion to be shot down in flames by the experts on here.
  8. RowleyBirkinQC
    RowleyBirkinQC Funster
    Sep 20, 2014
    1,112
    Dazed & Confused
    Ratings:
    +10,043
    We had trouble sourcing a new bung/plug for our tank (you don't always get the standard/expected water tank featured in manual), but no "slot" in our case. Ended up ordering an adjustable plug/bung from a chandlery. As long as you know the approx size of the hole, you can order one to fit which can then expand as required. Whether this approach may be enough to block the "slot" I know not.
    Are there any identifying marks on the water tank to enable you to identify manufacturer/model info? The manufacturer on our tank helped lead me to try the chandlery avenue (make boat related habitation equipment).
    Edit: it was one of these I think...
    http://www.chandleryworld.co.uk/cat...-drain-plug-for-25mm-fittings_p6598-1175.html
  9. BwB
    BwB Funster Life Member
    Apr 3, 2011
    731
    Suffolk UK
    Ratings:
    +808
    Fill the slot with something (glue, matchstick, whatever) then use a normal bung?
    • Nice One! Nice One! x 2
  10. jockaneezer
    jockaneezer Funster
    Dec 12, 2010
    2,446
    Cumbria
    Ratings:
    +8,051
    Could you file out the hole until the slot has gone and fit a bigger plug ?
    • Nice One! Nice One! x 1
  11. TerryL
    Mar 5, 2010
    2,381
    North East
    Ratings:
    +2,958
    That was going to be my next suggestion. Other than a new tank (expensive!).
    • Like it Like it x 1
  12. DonF
    DonF Funster
    Jun 18, 2016
    12
    Dumbarton
    Ratings:
    +1
    First of all, im not to happy about gluing the plug and i wish to thank everybody for their suggestions and their responses.
    I will try to identify the tank as suggested.
    Can anyone suggest a motorhome breakers yard?
    TIA
    Don
  13. BwB
    Apr 3, 2011
    731
    Suffolk UK
    Ratings:
    +808
    Maybe a call to CAK Tanks in the Midlands to see if they can help? They've probably seem most things tank related.
  14. gus-lopez
    gus-lopez Funster
    Aug 18, 2014
    8,400
    Lorca,Murcia,Spain
    Ratings:
    +24,272
    Cab you not turn the flash on on the phone camera ?
