IrasciBill
- Mar 6, 2010
- 194
- 37
- Auto-Roller 500
- Since 2009 (after many years camping)
Looking for advice on a couple of related electrical issues for which I'm sure some of you will have knowledge or experience.
Our new (to us) motorhome has been fitted with a battery isolator switch in the start battery circuit. Being on a Ford Transit base this is undoubtedly a worthwhile additional security device. However, when operated, it kills everything powered by that battery; including the trip computer and clock. Although this will minimise battery drain during longer periods out of use, it is a bit of a nuisance.
I am proposing to fit a fused link across the isolator switch terminals to maintain these functions but not allow starting of the engine. I was considering a fuse rating of about 2 or 5 amps as being adequate for this purpose but I notice that commercially available ones normally use a 15 amp fuse. I realise that things like the electric windows (and possibly even the ignition circuit) would possibly blow the 2 or 5 amp fuse if I forget to switch on the isolator before operating them. Is this why a 15 amp fuse is preferable or is there some other reason?
Secondly, with regard to battery drain, I am proposing to install a trickle charger for the start battery. (The factory fitted 12V supply / battery charger only charges the leisure battery.) Is it advisable / desirable that the trickle charger (whether powered or not) be disconnected from the battery before starting the engine?
