Hi,
At the moment i have 1 x 120 w solar panel fitted and i am adding another 120 w panel i have changed the charge controller to a votronic 250w/15 amp controller, at the moment the wire from the existing panel via controller to the two leisure batterys is 2 x 2.5mm, the new solar panel wiring is 2 x 4mm, there is no way i can get to the connection on the existing panel which is 2.5 mm cable, so if run the 2 x 4mm to the controller put a branch connector to join the 2 x 2.5mm into the 2 x 4mm cables and change the cable from the controller to batteries with 2 x 6mm cable, its 2 meters in length with a 20 amp in line fuse. Also there is already a 20 a fuse in the controller.
Does the above sound like the best way to wire all this up?
Also is a 6mm cable the same size as a 6mm sq cable.
I look forward to any advice.
Many Thanks
Bill
Many Thanks
Bill
