- May 19, 2018
- 225
- 353
Hi,
I have a sargent ec325 and also a separate solar regulator/charger. I have 2 leisure batteries.
Both of the charging units are currently set up with separate leads going to each battery.
I want to connect the batteries in parallel, so should I only use one connection to the combined battery from each charging source, or can I leave the system with the all the same connections and just join the batteries together?
Also, I want to connect an inverter to the parallel batteries. Should I connect positive and negative to different batteries or can I just connect to one of the pair?
Sorry if this has been asked before but most answers I see relate to multiple charging sources but don't mention the number of connections from each source.
