I had to remove the door skin to reattach a spring that had come adrift which prevented me from opening from outside. Unfortunately the seal was glued for a length along the bottom of the door.I'm intrigued as to what could go wrong with the inner seal. Just being nosey/inquisitive.
Have you got a picture of it or cross section, there seem to be lots of manufacturers/suppliers searched on google that will supply lengths. Just a quick search brings up the below. Not sure if you can make it work for you though.
Solve Your Sealing Problems | Rubber Seals and Trims
Seals Direct specialise in the manufacture and supply of rubber seals, trims and gaskets within the marine, industrial, caravan and automotive industries.www.sealsdirect.co.uk
Hi I've just had a similar problem with the door handle, is it straightforward to remove the inner skin to gain access? Any tips?Anyone had to source a new inner seal for the habitation door on Adria Matrix. My local dealer quoted over £200 to supply which seems ridiculous for a rubber strip. I cant find anything similar on searches.
