Adria Matrix 670sl (1 Viewer)
Tomos
7
5
Wales
A line Burstner ixeo
Recently purchased the above and am looking to put a tow hitch on the vehicle to pull a motorcycle trailer.
The dealer quoted an eye watering sum of money.
Any advice welcomed on tow hitch installers please
The Fossies
12
3
West Sussex
Low Profile
I'm a newbie
We had on Installed on our Adria Matrix Supreme and it cost around £1,300 ! - Used the dealer we purchased it from as they seemed most competent. I found out that a lot of tow bar installers couldn't source a solution due to the large overhang. I think Al-Ko supply a type-approved kit.
But whatever you decide upon it seems it will be expensive :(
Jan 13, 2014
3,601
11,580
Leeds - Yorkshire
I have to agree it does sound rather excessive, I would go down the local route before making a decision. They would probably need to see the MH to check out the overhang and Chassis but you don't get if you don't ask.
I would contact a local Trailer supplier who will obviously fit tow bars and ask them to take a look,I'm pretty sure they won't take the job on if there is any doubt to the fitting not being suitable to your vehicle.
WESTY66
5,815
14,253
South Yorkshire
Carthago Chic C-Line
All the gear, and no idea!
Old thread I know, but did you get sorted with towbar for your Adria? Just been looking at the same Moho and would need a towbar too!
Apr 9, 2018
8,633
44,558
Worcestershire
Bailey Adamo 75-4t
March 2018
Used these guys for my Matrix 680SP
It is basically a big chassis extention over a metre front to back and a big horizontal bar for the ball to fit on.
£1300 or so. I too wanted it for a motorcycle trailer.
MannClan
225
231
Peterborough
coachbuild
approx 2003
we have a tow bar on our 670sl but it is only rated for carrying bikes. when we were looking to do this we were told that the rear area would need strengthening if we wanted to tow a vehicle and that it would cost quite a bit. as we only wanted to carry bikes not too big an issue but still had to go and get it manufactured to fit rather than one off the shelf.
Jul 2, 2017
587
478
Pr9 9qs
Adria matrix 670sl
Got quite a beefy looking one fitted to our matrix will have a look next time for the makers plate
Aug 15, 2019
69
58
N Lincolnshire
Burstner Lyseo 728G
2 years in
got one on mine fitted by towtal, came with it on so don't know cost but they are motorhome specialists by all accounts
Apr 28, 2013
3,682
80,851
Alentejo,Portugal
Hymer A Class
Since the '80,s
We had one fitted on our current van by Watling at St Albany’s,was £1200 but a lot of metalwork.
Last van had it fitted by Towtal in Stoke,lot cheaper and nearer for you possibly.
Joc
Jul 5, 2018
38
71
Bluntisham, Cambridgeshire
Adria Matrix 670 SL
Since 2018
Hi, I had a towbar fitted by Watling Engineers of St Albans. Not cheap (about £1600) but I had the scooter carrier fitted as well (can carry a small scooter/motorbike up to 120kg). Very substantial piece of kit which involves inserting steel strengthening bars into the aluminium extensions. These are fixed to the main chassis with bolts and strengthening plates. Mine came with a tow ball, which can be fitted in place of the carrier, and all electrics. The whole kit is officially certificated for the van. Hope this helps ?
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
Jul 12, 2013
3,872
5,274
The City of Henlow
Adria Supreme
Since 1980
I also have a Matrix Supreme but am concerned that the garage is rated at max 150kg. Adria also fitted a spare wheel. I do not know if the 150kg is in addition to that. My point being that a tow bar must eat into this limited payload if only used to carry bikes etc. Pulling a trailer should be ok!
Joc
Jul 5, 2018
38
71
Adria Matrix 670 SL
Since 2018
Rosalan, the weight of the spare wheel does detract from the carrying capacity in the garage. I believe the weight limit is to do with the material of the factory fitted chassis extension being made of aluminium alloy for weight saving.
Which is why, when I had my tow bar/scooter carrier attached, steel inserts were fitted. These steel inserts are bolted into the vehicle chassis with strengthening plates, all designed to increase the load carrying capacity of the rear extension.
This, obviously, decreases the vehicle carrying capacity by the weight of the extra material (about 50 kg), but it's a personal choice as to the benefits.
I have air assistance fitted on the rear suspension to improve the handling and stability. This also has the added benefit of preventing the rear suspension from sagging over time.
Joc ?
Apr 20, 2012
428
455
derbyshire
Camper van
1year 10 times
Hi just found these oldish threads and looking at an Adria coral 670 twin bed and would need a tow bar to tow an a frame and small tow car any further information orupdate would be most welcome tia
Jul 2, 2017
587
478
Pr9 9qs
Adria matrix 670sl
Think the tonyidle price is worth a look at seen a receipt for mine before I purchased van £1600. Glad I didn’t foot the bill
