Adria coral control panel LT313
Nomadian
Not up Jim’s arse like some
Hymer
More than some less than others
I have just changed the engine battery on my 2013 fiat based Adria Coral and the control panel is now flashing a warning triangle and showing the engine battery as <11v, it’s not the van starts ok and multi meter is showing 13.5v with engine off. Any ideas anybody? Fuse? Is there a way to reset it? I’ve had a read of the manual and can’t see anything anywhere. TIA
Is this an ECU issue? Does it require a reset? I read about it on here somewhere, anybody know the correct sequence?
The system on my Adria needs to have the battery fully charged and then the system needs to be left alone for a while to calibrate. This is what I had to do after fitting new batteries in mine after informing it of the power of them.
