Hi all
Have just trialed using Adjustable Decking supports to stop my MH from rocking.
Used the usual wind up steadies on the rear but prior to fitting them I placed 2 decking supports under the jacking points.
Wound them up 'hand tight' then used the standard wind up steady on the rear. The end result was surprisingly good, no significant rocking for the first time. The rear steadies applied sufficient load to neq steadies to counter act the front springs.
The new Adjustable steadies have a higher load capacity than the rear steadies but cannot be easily adjusted once fitted.
