Adjust 2001 2.8hdi cllutch cable.
68c
Southampton
2001 Pilote 270
Since 2004
Starting to get a bit of clutch slip when climbing hills in fourth, OK if I back the throttle off a bit.
Unsure about how to adjust the clutch cable. An unusual layout to me in that the inner cable is fixed to the gearbox casting and the outer casing pushes the clutch lever towards the engine to disengage. So to allow the lever to move to its rest position the outer sleeve appears to need to be slackened by backing off the two jam nuts. I have tried that but it results in the pedal sitting higher than before. Any suggestions?
If the pedal has remaining upwards travel as you say then it's not tight enough to cause slip,from what you state time for a new clutch
In my heart I know you are right. Just need to baby the van along from Fort William to Southampton. At least it is downhill according to the map.🙂
