- Sep 29, 2019
- 3,486
- 7,946
- Hymer Exsis
- 20 years
Saw one on a mates van and it gave off a great light, much better than my dismal attempt at a light above the door.
However, no way am I paying that for it. I therefore looked at Amazon and the same one virtually can be had for a tenner. I have used this brand before but the non waterproof version and have been impressed with the quality for the cost.
Amazon product ASIN B00HSF66JO
So it arrived and the first thought was how to get to the existing awning light cable, turns out very easily as I could just unscrew the control panel and there it was. Sorry but yes, I used scotchlocks. They are easy to get to if any issues so not that fussed about a bombproof connection.
So once I knew where the cables were and how to route them, I stuck on the strip. It is self adhesive and a quality one at that. Avoid the cheaper versions, this one is 3M branded.
Literally just peel and push on, ensuring all bits are stuck.
Once you have reached where you want it to finish, just cut it to length across the marks and stick down. I used some silicone to seal the end to prevent water ingress where I cut it.
Then the scary bit of drilling a hole in the van. You don’t get a lot of cable on the end and I could only just crimp the cable on so keep this in mind.
Once all crimped up and the cable was run I tested it and all working.
The bed curtain hides the cable run except for the last few CM. This was annoying me, I also come to the conclusion I might want to switch the big light off and only have the smaller light on. So I added a switch that also hid the wires.
It is a domestic switch but blends in and cost less than a fiver.
Finally tested it and all working. Took 30 minutes including putting the tools away. Sealed all up with silicone. I did consider sikaflex but the hole is very small. I also made sure I drilled in at an upward angle so water drips away from the van.
In short, well chuffed for the money. Probably cost £14 all in for the bits.
Hope it’s useful for someone considering the same.
Thule Self-Adhesive Awning LED Strip - 5m | Leisure Outlet
www.leisureoutlet.com
