Swifter
Total cost £4.99. Just plug in and use when required . None of these fancy dash mounted buttons to inflate/deflate but will do the job at a fraction of the cost .
On the van, I use a micro sized bicycle hand pump. The valves were next to the handbrake, attached to the driver's seat frame. The volume and pressure required in the bellows is so low, it only take a couple of minutes to inflate it from flat.... although I did used to get some funny looks as I pumped away.
Total cost £4.99. Just plug in and use when required . None of these fancy dash mounted buttons to inflate/deflate but will do the job at a fraction of the cost .View attachment 495366
Correct . If we arrive onsite and need to drop the back end to lower it I just let the air out and then connect the compressor and put some air back in when we set off again .So you're manually connecting it to each side and then just switching it on/off ?
I had a temporary contract as a Housing Officer in the Gorbals some 21 years ago and used to walk to the office along the riverbank [beautiful at this time of year in the early morning sun]. At the start of the footpath was a Glasgow City Council sign 'No Dumping'; the local wag had extended the 'D' to alter the sign to 'No Pumping' ... and I never saw anyone breaking the byelaw ...On the van, I use a micro sized bicycle hand pump. The valves were next to the handbrake, attached to the driver's seat frame. The volume and pressure required in the bellows is so low, it only take a couple of minutes to inflate it from flat.... although I did used to get some funny looks as I pumped away.
Do you have a link on we’re to get those gauges and surround TIATotal cost £4.99. Just plug in and use when required . None of these fancy dash mounted buttons to inflate/deflate but will do the job at a fraction of the cost .View attachment 495366
The gauges and surround were on the van when I got it . I will see if I can find any onlineDo you have a link on we’re to get those gauges and surround TIA
Macca
<Broken link removed>Do you have a link on we’re to get those gauges and surround TIA
Macca
Cheers for info. HOW MUCH<Broken link removed>
Cheaper seat mount gauges are available......I thought you were specifically looking for the ALKO air top gauges.Cheers for info. HOW MUCH
No mate just seen the gauges looked the part. Wether it’s al-ok or not it’s only giving an air pressure reading. Thanks any way for responseCheaper seat mount gauges are available......I thought you were specifically looking for the ALKO air top gauges.
Also bit of a joke.300PSI maybe a bit OTT
