Access to underfloor bathroom plumbing on 2007 Arto
Andy Bramhall
Newcastle
2007 N-B Arto 69 EGB
I'm a newbie
Hi! Does anyone know how to access the bathroom plumbing underneath a 2007 Arto?
I can see that the shower drainpipe has become detached from one of the shower plugholes - but I can't work out how you get access to it underneath the bathroom.
Thanks for any help you can give!
Andy, if it's anything like our 2006 Flair, you might gain access from the base of the wardrobe next to the shower compartment.
I've had to remove the middle and bottom kitchen drawer plus the boiler hatch, to gain access to the outlet pipe at the bottom of the fresh water tank, which needed replacing. It was an absolute nightmare :swear2: as was moving the boiler to gain access to replace the burner and igniter assembly. Both jobs took me many hours. :( Be prepared for bruises and some skin shedding. ;)
Good luck. (y)
Jock. :)
Im in a similar position with my 2004 Euramobil shower waste. The underfloor trap has snapped off the above-tray grate, and it's out of reach from the hatches near it in one direction and behind a wall joining the two floors in the other.
My current thought is that I need to lift the whole shower tray, but as the tray is the same size as the shower cubicle that means removing the waterproof wall boards as they overlap the tray and that means removing the waterproof ceiling unit as that overlaps the wall boards !!!! NIGHTMARE !!!
No. I haven't got a clue how to get under the floor - see attached pics!
Which drain is not connected?
The back comes out of the basin unit.
The drain that has detached is the shower drain that you can see just next to the toilet.
I don't know how to access that under the floor...
I assume you have had a look through the toilet cassette opening, would it help if you removed the toilet ? a bit extreme I know and especially of you are not sure it would help.
I agree. If that one pull the toilet.
Thinking about it though the cassette is usually in it's own plastic liner/enclosure so may not give access as required.
Agree, but on mine ( less posh not an Arto:giggle:) I think that enclosure can be removed separately from the shower base as it sits on top of it. But I haven't actually done this so I may be completely wrong....
It so near that it has got to be the worth pulling, possibly so something can be cut or removed, but eventually hidden.
OK - I can have a look at that tonight and see if that enclosure for the cassette can be unscrewed.
Thank you.
Hi don't know if you can get access from the garage ,taking off the panel to access the pipework below( since it the drain nearest the garage).
I don't know if it's possible to reach the connection by removing the heating pipe that's above the water pump,it must be about this area.
Thought I'd throw it into the equation incase it's an option,my garage is full so can't look myself at the moment .
Good luck
Cheers Cris 🍻.
