A-framing A “TOAD” in France. (1 Viewer)
Apr 12, 2020
985
997
South Lincs....
Rapido 7095DF
20+ years. Previously Hymer B654 and Hymer S660 both c/w tow-bars.
There is much said about the legality or otherwise of a-framing a towed car.
BE AWARE! There is a post this morning on a FB a-framing group where the poster says “Just been pulled by French plod for my tow car!!”
It’s fair to say that enforcement is patchy at best but, caution is required!
Northernraider
25,818
151,474
On the sofa ....
Hymer 654
On and off since 95
It's the same as driving around the UK with bald tyres or no licence.
You might get away with it for days,weeks,months or even years.
But at somepoint you might get caught
Chris
20,822
258,286
None
10 years
I saw one happily driving on the motorway in France last week
Sep 13, 2016
447
39,045
Okehampton
Swift Mondial
Since 2016
Just driven past Toulouse and the signs on the autoroute were showing crit air 4&5 not allowed in the city!
TonyEmm
Apr 12, 2020
985
997
South Lincs....
Rapido 7095DF
Yebbut, what was the result?
Fined?
Had to decouple and drive separately?
Just a chat?
(I don't do Faecesbook).
He had to uncouple and drive separately. Fortunately, had a 2nd driver!
He tried claiming he didn’t know it was illegal, which might be true as someone clocked the same outfit in the U.K. on dashcam, with no retro-reflective triangles on the rear…. Ignorance or arrogance?🤔
Feb 22, 2008
12,180
44,231
Norfolk
Hymer B544
Since 2004
A Frames/ Flat towing toads far safer and more convenient than trailers but illegal on most of European mainland.
Dec 17, 2019
914
1,632
St Leonards, Dorset, UK
Carthago Malibu
Converted caravanner!
Seen a couple of UK MH’s this week here in France with A frames. It’s one thing having a bit of cheese in your fridge but this seems a very risky chance to take.
Dec 24, 2014
8,470
41,778
Hurstpierpoint. Mid Sussex.
Compass Navigator
Ever since lighting was by Calor gas.
Not all; there's no risk from having French cheese in your fridge and if a gendarme starts giving you grief about your A frame you can stick some in your ears.
TonyEmm
Apr 12, 2020
985
997
South Lincs....
Rapido 7095DF
2 mo
2 more stopped in Germany this last week, one was 50yds from the Austrian border! Had to uncouple and fined…. 😏
Apr 9, 2019
402
358
East Riding Of Yorkshire
30 years Caravan 13 years Motorhome
Recently in the Dordogne and met a Brit who has been towing his A frame with no problems for the last 18 years. Also saw one French M/H towing on A frame and met other Brits this trip out who have seen some French towing A frames which are called Blue Frames in France. So maybe things are looking up
TonyEmm
Apr 12, 2020
985
997
South Lincs....
Rapido 7095DF
The ‘Blue Frame’ you refer to is the http://systeme-bleu.com/accueil/?fb...Fqyq2mxuu959LkyI2q8sphfYyyMP6zZOBNmaagL_-sgZE made in Castres, in the Tarn region, near to where my son lives. It’s a copy of the Caratow, made in Dorset. In common with the majority of U.K. suppliers, they claim it’s fully legal and even suggest type approved (though only the Alko coupling is tested and approved). As it‘s inertia braked, it contravenes regulation 13 para 5.2,2.2 of the UNECE regs, so is illegal across Europe.
Note that it isn’t illegal to supply it, only to use it! However, as enforcement is patchy at best, the likelihood is you’d get away with it…. Doesn’t change the law though! 🙄
bigtwin
4,725
8,949
Derby
Concorde
Since 2006
There have also been a couple of FB posts this week reporting no interest from Gendarmes. One in particular was given the thumbs up from Gendarmes driving through an aire.🤷‍♂️
Ian
TonyEmm
Apr 12, 2020
985
997
South Lincs....
Rapido 7095DF
Ian
There are plenty of reports of ‘no interest’ by gendarmerie and so on but, it doesn’t change the law. It’s luck of the draw whether or not you get stopped!
bigtwin
4,725
8,949
Derby
Concorde
Since 2006
The law isn’t under dispute, I was, like you, merely pointing out what has recently been reported on FB. 👍
Ian
Jul 29, 2013
8,861
16,108
Salisbury
Hymer B678DL A class
since 2011
Could you explain why it’s safer please ? As I’ve towed a trailer for the last seven years without any issues🤔
Feb 22, 2008
12,180
44,231
Norfolk
Hymer B544
Since 2004
I have towed trailer and for some years flat towed toad . At the time my Peugeot 107 on a Brian James trailer was at least 18” further from the road being supported by two wheels the nett result being a much higher centre of gravity leading to poorer stability and greater risk in the event of trailer tyre blowout and braking through just two wheels as opposed to all four with toad on road.
I only flat tow in U.K. and have the advantage of not having to locate a trailer on pitch on sites.
The only disadvantage of a framing is a limitation on reversing but over many thousands of miles I have only needed to “shuffle” on a couple of occasions when in a tight filling station with no problem.
Jul 29, 2013
8,861
16,108
Salisbury
since 2011
Perhaps your theory is correct for two wheeled trailer however a twin axle trailer is far more stable and tows really well😊
I realise it’s a matter of personal choice but you can’t pigeon hole all trailers the same🤔
Feb 22, 2008
12,180
44,231
Norfolk
Hymer B544
Since 2004
I agree a personal choice .
6
62272
Centre of gravity is lower, although neither is unsafe unless you exceed the speed for the conditions, or steer too harshly.
