D
Deleted member 29692
Does anyone know if popcorn is actually legal in Spain?
Only if sold from a vehicle being towed on an A frame
Thank you for clearing that up Nick.Only if sold from a vehicle being towed on an A frame
It is so lovely to see a thread were everyone is getting o n so nicely keep it up fellas, I admit was a bit hesitant to post such a thread about tow cars and towing loll, i can see I won't be needing any popcorn for this thread x thankyou
Regards Kate
I think, like other aspects of legislation that affect our hobby (C1 licence laws for example), that it's a lack of legislative interest rather than a deliberate attempt to prevent the use of a perfectly sensible device. I have no doubt that there was a perfectly valid reason for Spains car towing laws and that hobby A framing is simply an accidental casualty. Even in this country there's no political will to rewrite trailer legislation to accommodate a small user group with no political clout.I personally think the following Sum`s up "A" frames.
" A perfectly satisfactory TOOL, which is a Victim of Bureaucratic Stupidity"
my 4 wheel boat trailer has an all up weight of 3.5 ton has cable brakes and no servo, and stop's ok, my toad has a cable and stop's superb never had an issue stopping while towing a toad.Good points - I think the A Frame industry would be happy to have clarification of what the standard should be for these devices. I would not be happy with a cable operated brake on an A Frame that does not have servo assistance - ever turned your engine off and coasted until the vacuum on the servo has run out and then tried to apply the brakes - the pedal needs standing on for any braking effort to happen. There are two schools in A Frame technology - do it on the cheap (£1000 fitted) cable operated braking no servo assistance - do it right (£2500 fitted) electronic inertia sensor/vacuum pump servo braking. IMHO the latter should be the standard.
Sorry for my ignorance but what actually is an "A Frame" trailer ?
The reason I ask is because a good MH technician has just left our local dealer and has set up by himself about 10mins away from us and he's now selling the YORemorques range, but is that an A Frame ?
Just curious as it may be a solution to our weight management.....
PS: these have a way to lock the trailer when reversing as the wheels pivot although it looks like a bit of a faff to me.
Correct term would be a Motor Cycle Trailer.
Most defiantly NOT an A Frame
No never turned an Engine off and cruised BUTGood points - I think the A Frame industry would be happy to have clarification of what the standard should be for these devices. I would not be happy with a cable operated brake on an A Frame that does not have servo assistance - ever turned your engine off and coasted until the vacuum on the servo has run out and then tried to apply the brakes - the pedal needs standing on for any braking effort to happen. There are two schools in A Frame technology - do it on the cheap (£1000 fitted) cable operated braking no servo assistance - do it right (£2500 fitted) electronic inertia sensor/vacuum pump servo braking. IMHO the latter should be the standard.
Thanks, popcorn required in Europe for that type ?
There should be a system in between those two cost-wise. A simple vac pump and two non-return valves would keep the servo going & shouldn't cost a fortune. @chrisgreen your comment is fair enough but the trailer linkage & lever ratios are set up for overrun braking. A small car will be fine with a pedal-pull cable but as things are someone could be A framing a couple of tonnes. An active servo is probably essential with a heavy weight car behind.Good points - I think the A Frame industry would be happy to have clarification of what the standard should be for these devices. I would not be happy with a cable operated brake on an A Frame that does not have servo assistance - ever turned your engine off and coasted until the vacuum on the servo has run out and then tried to apply the brakes - the pedal needs standing on for any braking effort to happen. There are two schools in A Frame technology - do it on the cheap (£1000 fitted) cable operated braking no servo assistance - do it right (£2500 fitted) electronic inertia sensor/vacuum pump servo braking. IMHO the latter should be the standard.
Cars such as your Herald have a different hydraulic ratio to a modern car. Back in the day, when adding a remote servo was a popular pastime, what you say was true. It isn't these days. Whilst you are correct about driver effort the reality is that the hydraulic ratio design of a modern car assumes there will be an operating servo. It is still possible to brake adequately without the servo in use but the amount of pressure required to do so is such that all sensitivity is lost and the effort involved means that it isn't safe to do it except in an emergency situation. It is equally possible that the tension required in an overrun cable is beyond what the hitch and its damper were designed for. You are correct about reversing too, or you were, because legislation changed in 1989 to require all trailers to be capable of reversing without the driver having to leave the towing vehicle.On the subject of "Servo" brakes. My 1971 Triumph Herald, has no Servo, Very few cars Prior to the 80`s had Servo Brakes, the braking effort IS THE SAME. The only difference is that the effort of the driver is less. You CANNOT improve braking with a servo, the Physics are against it!. An "A" frame does not need servo assist, all 4 wheels are braked and the effort is supplied on the overrun and is a function of the potential difference in Mass/motion between the 2 vehicles. I have had a 4 wheel "lock-up" on the toad, in a "Crash" stop. The brake efficiency is not the question, ability to reverse is, but in my view that is a total "red herring", as older Caravans had to be "locked" before reversing, requiring the driver to get out and "set" the lock!. In fact I would suggest that it is quicker to get out uncouple and move the car, as opposed the reversing a Trailer, especially if the distance involved is more than a few yards!.
As for legality.
Unless it’s against the law it is legal by default. One simply cannot be prosecuted unless a law is in place and written down. In certain country’s there are laws written down but any law is challengeable and bloody challenge I would in the VERY SLIM chance I got pulled. QUOTE]
This is where some of the problems exist. In UK law it is legal unless it is specifically banned. Abroad it is banned (illegal) unless specifically allowed by law.
The point I was trying to make is that "Universally" legislating for Doubtful and expensive "improvements", is IMV, unnecessary. When something simple WORKS, Why alter it?. (KISS). The cynical (and I am one of them) would say it does improve "profits" for the manufacturer, the extra complication adds more to go wrong, and of course like we see with "modern" vehicles there is less scope for the skilled, DIY`er to tend to His/Her own maintenance, as owning the very expensive testing equipment is not cost effective. As a glaring example, I was quoted £80 plus VAT, JUST to extinguish an MIL light, which was the result of having to remove a Seat for access!. (In the event, I spent the £80 on a device which can do that, and a whole lot more!).
The early pattern "A" frames are largely over engineered, and I have only ever heard of one incident of failure, and that was where one of the "new" breed of lightweight "all singing and dancing" frames was bent. Even then the toad did not detach from the towing vehicle, but did tend to crab sideways and scrubbed the tyres!.
As for a difference in Hydraulic ratio, I have to say I am just as cynical, I have seen no evidence that the Ratio between the Size of the Master and slave cylinders has changed for any given class of vehicle?, but no doubt someone in the "industry" will know?.
Never said otherwise. However the effort required by the driver is considerably different and a cause for concern in itself. That may or may not impact on the cable pull arrangements of an overrun-type A frame. A light car barely needs to brake when towed - it won't be much over the weight of an unbraked trailer. A heavier car (if anyone uses such a thing as a toad) will certainly need to brake.Stopping distance in this case is both irrelevant and arbitrary. the stopping distance will depend on many factors, tyres weather, road surfaces etc and can not be compared between two different vehicles.
My tests were conducted with calibrated equipment designed solely to measure applied braking force
and clearly showed that the mandatory braking efforts required for the weight of individual vehicles could be met with or without servo assistance
G
As for legality.
