A frame towing in France (1 Viewer)
May 7, 2016
7,185
11,604
West Sussex
Carthago Compactline
Since 2003
I think these are more typical and look more robust.
May 20, 2009
782
856
Haute Vienne, France
So. Was it a ‘wiz bang idea’ to get around the A frame rules in France by fitting one to a 2CV due to its low weight (below 750kgs including the frame)?
NO.
Could you get away with it, as many do? Well. Do you knowingly break the law regularly in the UK in any way? If not, why would you knowingly break the law in France
Many do break the law here in France frequently by not registering their vehicles and driving around still with number plates of their former country.
Apr 12, 2020
1,021
1,034
South Lincs....
Rapido 7095DF
20+ years. Previously Hymer B654 and Hymer S660 both c/w tow-bars.
30x30x3mm Tony, now don't be silly it obvious you have never seen how the crossmember is attached to the front of a car, in an extremely unlikely jackknife situation it would simply tear out of the front of the car leaving the box undamaged.::bigsmile:
Have a look at all the professional ones made in the states, no one uses anything stronger and they don't seem to have a problem.
A frames are different to drawbars as they don't have to bear part of the weight of the trailer so don't need to be so strong, and trailers have to be designed as you know for numpty's loading them badly, putting excessive weight on the drawbar and towing vehicle, as we see with caravans all the time.
I’d agree you’d probably rip it out of the car first!
Jackknifing is certainly less of an issue with a ‘toad’ simply because hardly anyone ever reverses them! That said, I have had bent drawbars caused by exactly that and, they were bigger section than 30x30....
The weight bearing bit is an issue with trailers. The heaviest stress is under the front cross member. Jackknifing is a whole different set of stresses though, once it’s gone, if the driver isn’t aware, he’s trying to push the ‘trailer’ sideways..... With a ‘wheel at each corner’ trailer, it just isn’t going to go!
Jul 29, 2007
6,526
39,280
Ipswich
RV and PVC
30 years
No brakes by the look and I would say over 750kg, so no surprise it jackknifed, bad driving on your part. :giggle: There's no way the under 1 ton Alto is going to push my 9.25ton RV anywhere.
Apr 12, 2020
1,021
1,034
South Lincs....
Rapido 7095DF
😁🤪😜. It wasn’t me!
the coupling etc has been removed, brakes are disconnected....
The problem will be when your 9.25 ton RV is pushing the under 1 tonne Alto sideways! 😁
Apr 12, 2020
1,021
1,034
South Lincs....
Rapido 7095DF
😁🤪😜. It wasn’t me!
I know I first commented on the size of your ‘A’ frame but actually, when it came to jackknifing, the biggest issue was usually with the draw tube in the coupling bending. Bearing in mind that’s around 50mm ext diameter and up to 10mm thick wall, that’s a LOT of stress. The problem then was that having sorted the jackknife, the driver carries on his way and first time he braked fairly hard, the draw tube compresses... and jams... locking the brakes on.... I’ve seen that a good few times on caravans And it happened occasionally on my trailer hire fleet.... 🤬
PeteH
6,853
9,029
East Riding of Yorkshire
Rapido, 999M.
18+yrs plus 25+Towing
The blue ox tow bar, with which I travelled near 20k miles and 27states, towing a full size Toyota Tacoma 4wd pickup was a damn site lighter than the Caratow I currently use on P107!. If there have been issues with them they are so few that I don't ever remember reading about it in the US press or online. There must be hundreds of thousands in use stateside by now.
bobandjanie
8,143
15,699
Javea, Spain
Pilote V600g
This came on Facebook memories 12 years ago in France, our first motorhome and toad with a car a tow a frame, 🤔 the memories we have is all the germans taking lots of interest in it and how it worked 😉 the engineer coming out of them. 😁 Bob.
Aug 6, 2013
11,941
16,527
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
You're on the wrong side of the road & someone has dumped a genny behind the toad ::bigsmile: .
Jul 29, 2007
6,526
39,280
Ipswich
RV and PVC
30 years
In France with another blown tyre:
Oct 23, 2022
VW T4.
OK... gross weight is the fully possible laden weight with four people in the car plus any luggage
But surely its rediculous to add the estimated weight of four passengers to the gross weight of the towed car, when it is illegal everywhere to tow a vehicle containing passengers.
Apr 12, 2020
1,021
1,034
South Lincs....
Rapido 7095DF
As usual, I don't understand your comment. The total weight of a 2CV is 600kg, the A frame will not be more than a 100kg so what is you point on that please?
Please clarify.
The maximum Gross weight (or Maximum Authorised Mass, if you prefer) is the figure shown on the vehicles VIN plate. The kerb weight or unladen weight is irrelevant as far as braking regulations are concerned.
In any event, as the trailer (TOAD) is equipped with brakes, they have to be operational and, it has to be auto-reversible To comply with trailer regulations.
https://spinner28.wixsite.com/tonys-towing-trivia/post/weights-vin-plates
