Realist
- Nov 4, 2018
- 1,747
- 2,667
- Caravan: Buccaneer
- Caravan before 2000 / Motorhome From 2018 to 22 / Now Caravan again.
Found this on one Facebook forum.
Absolutely!Also these systems are dangerous and should not be allowed.
Freedom of choice?Whats wrong with going all out and putting car on a trailer or even better become a tugger.
Three thoughts. The corrosion is pretty much only where the fixings went through so they’ve probably drilled holes and then not protected the holes. It’s been failing for a while, so hasn’t been checked on. Also these systems are dangerous and should not be allowed.
What are your qualifications for making what appears to be a generalized inflammatory remark?Absolutely!
The whole forum is full of experts, hahaWhat are your qualifications for making what appears to be a generalized inflammatory remark?
Far more than anyone who built what I have seen here.What are your qualifications for making what appears to be a generalized inflammatory remark?
Whichas I have said before, then makes the whole car illegal as in Breach of its Certificate of Conformity as it would require that the replaced front beam had a CoC homologation the same as any type of tow bar has to have.and some actually change the whole front end that’s been strengthened and modified to stop such a disaster.
And joined to the longitudinal beams. I've seen several cars with rust at the cross member / longitudinal intersection....Thats been a very poor fitting ... both the towcars ive had were over engineered and had a full galvanized beam bolted along the full width of the front cross member . That one looks pathetic to be honest
