- Mar 15, 2019
- 518
- 933
- AutoCruise Stardream
- Newbie April 2019
Our 2007 Autocruise Stardream has a Sargeant control panel and 90w solar on the roof. The Sargeant controls the charge, I assume by PWM
I store the MH inside at work so end up moving it most days so we can use the workshop.
Having read some of the solar panel/charger discussions on here I wonder if fitting a better controller (mppt) to eek a bit more out of the humble setup we have would be worthwhile. Also as its moved regularly the battery needs charging every so often as doesn't get run long enough
If we had a better controller that did twin batteries it would be dual benefit as the batteries will get a bit of charge during the day and reduce how often I have to put it on hookup. Also when we do get to use the MH a more efficient setup is never a bad idea
Seen the Victron MPPT 75/15 but only seems to do one battery, or maybe spend more and look at the Voltron 250 one that does twin batteries and futureproofs us if we add more solar. But thats unlikely for now
Our current setup only charges when the panel is turned on, then when I move the MH it turns it all off.
Can the others be left on full time to maintain things?
Any of it sound reasonable or a waste of time and money?
