Paul and Pippa
Hello all...I'm buying a used MH ...what's the pro's and cons of A class or coachbuilt..any advice please
Don't touch an A class. Upwards of £30,000 for a windscreen and you wait months to get one. £10,000 for a wing mirror. And servicing, you can't service them, only a gynaecologist can service them and you know what they charge.
Whereas C class, any van garage can sort them out for about 7s 6d.
7/6 ???
Jeez, Obi Wan, showing your age, you are!
OP don't listen to this rubbish my windscreen only cosy £29000 delivered and the gynaecologist also delivered cheaply.
lastly older vans don't show their age the same when they are "A Class".
Martin
Nonsense.
Follow and old A-Class and you are swerving all over the road dodging lumps of rotting iron and shattered headlamps.
I omitted to mention the headlamps, upwards of £10,000 for a headlamp and £20,000 to £30,000 to fit it.
Only in Salford.That got you a bottle of whisky and a hot woman in my day.
So why not a 6 metre A class?I would say that a lot depends on the intended use of whatever is bought. If, for example, I was going to spend several months of every year parked up on a campsite in Spain, then it would be an A class. A larger one at that.
However, thats not my idea of using a motorhome. I like to travel about, and for that a 6 metre or under PVC or Coachbuilt has all the advantages. Easier to drive in traffic, cheaper on ferries, in my opinion, cheaper to run generally. When I'm somewhere, I'm very rarely in it other than for sleeping, so dont need the space of an A class either. The one I own is a "Scandinavian edition" therefore winterised as well.
So for me personally, an A Class has only disadvantages - but I can see the reasons others prefer them. They are just not for me.
Martin
thank you,didn'tknow thatMore expensive on toll roads if over 2.9metres high .
Just about to change from A Class to Coach built (ish).
A class looks good, gives a feeling of airy space and great views when driving. But most people when they stop turn the chairs round so they cannot see out of the windscreen.
Coachbuilt, less stress over windscreen damage, 2 doors better, easy and cheaper screen protector, less bug cleaning, wipers work better, easier to reach windscreen to clean, engine work easier and cheaper, mirrors are cheaper and available, mirrors can be pulled in, less glass easier to keep warm and cool, etc..
Insulation, double floors etc are all about the build, some A Class are great but so are some coachbuilt it is dependent upon the conversion not the format.
Learning that it is all about layout and function, format is secondary.[/QUO I'm just about to buy a MH and go full timing, My friend said I will not go wrong with a German make MH..you have just given me something to take into consideration ,,thank you that's very helpful
But whether it's an a class or not doesn't depict the height.thank you,didn'tknow that
Quite right will never happen to most and cost is covered by insurance.What is this stress over a class windscreen, I don’t and can’t see the problem, if it’s insured you only pay the excess as with any other windscreen.
How often does an a class windscreen break, possibly never for most owners .
It is the wait on a non standard piece of glass being shipped and then fitted as opposed to a standard model more readily available.
