- Oct 29, 2016
- 4,504
- 52,725
- Carthago C Tourer
- Motor Homing 5 years, caravan previously
Just a quickie question, going to fit Bullfinch BBQ point this spring to new MH.
Checked out Hamilton Gas Products, they have all the parts required except an 8mm compression TEE fitting so I can take a feed off behind FF.
Is it OK to fit a compression Tee or do I need to fit a soldered TEE Fitting as its gas?
If it does require a soldered Tee Fitting then thats OK, but seemd strange as the 8mm gas pipe would start and end in compression fittings as you know.
Would have also liked to to fit a Gas Tap to isolate, but dont think I have room to extend existing gas taps under hob. I will know more when I have the cupboard drawers out and can see what I am left with.
Thanks for any help on this task.
Les
Les
