MisterB
- Feb 25, 2018
- 7,094
- 16,603
- Adria 670 SLT
- enough to know i shouldnt touch things i know nothing about ....
i have started to fit an 85cm sat dish to our motorhome (Adria 670 SLT) but have run into a couple of 'issues' to overcome.
firstly - the footprint of the sat dish when laid flat doesnt actually fit anywhere within the 'railed' area on the roof, as it stops the main roof window from opening fully - my solution is to remove the rail that runs across the front and refix it (rivet nut gun on order for tomorrow) further along, which then allows the sat dish to be fixed to the roof (sikaflax onto a well prepared surface !!) and rotate without obstruction.
secondly - when fitting previous sat dishes (this is my third) i have always positioned it so that when the dish is housed, it folds down with the hinge mechanism pointing forward, im my mind so that any wind when travelling should travel over the top and not underneath (hope that makes sense ?) however, due to limited space on the roof, i have to mount this one with the hinge parallel with the side of the van. it wont create a wind block when housed for travelling. Does anyone see an issue with mounting it this way? i intend replacing the rail which will interfere with the travel/rotation of the dish if i position the dish in its preferred orientation. of course i could just not put the rail back, but that would be cheating LOL !
The dish isn't in its final position but shows the orientation I will be fixing it in.
