8.75V (1 Viewer)
DFMan
41
13
Lancashire
Toyota Dyna
Newbie
Hi Folks,
That's the multimeter reading straight off the Leisure battery. I have read quite a few articles on leisure batteries but being a complete newbie I thought I had better post here to get some advice.
The battery is a
NUMAX LV26MF
Is there a point in rescuing it?
Jim
Ringleader
Jul 19, 2007
36,317
130,212
Sutton on Sea, UK
Adria Panel Van.
Since 1988
I think it as dead as a Norwegian Blue, but it might be worth having a go at it with a charger that conditions as well, some say they have them recovered them from such low voltages.
DFMan
DFMan
41
13
Lancashire
Toyota Dyna
Newbie
@Jim Unfortunately I would have to buy a battery charger/conditioner as I don't have one. So it looks like it's going to be a new one. Are they reasonably straight forward to fit yourself?
Oct 2, 2008
4,464
7,931
Salopia
Duro 6x6 Overlander
since 1968
Yes , take of neg terminal first . Remove second terminal . remove battery holder, and fit new reverse order :) If you have solar make sure you disconnect solar first.
Apr 27, 2016
6,855
7,957
Manchester
A class Hymer
Since the 80s
You don't say why the leisure battery is discharged, but you need to know that often a flat battery is a symptom of problems elsewhere, either in the charging or consumer items. Keep an eye on the voltage of the new battery to make sure it doesn't go the way of the old one.
DFMan
DFMan
41
13
Lancashire
Toyota Dyna
Newbie
@autorouter I have no clue on that as I have just bought the MH.
Has anyone got any recommendation regarding make and model?
irnbru
13,511
31,136
Glasgow
Benimar 264
11 yrs
Where about are you? Someonenearby might let you borrow their charger. If your anywhere near Bellshill you can borrow mine.
scotjimland
2,246
9,757
A Woosh bang
I would say it's buggered.. technical term.. at that voltage at least one cell is probably dead or short circuit .. don't waste time or money trying to recover it.. even if you do, it will probably be damaged and never give the service you need ..
Make and model,
Tanya batteries will supply like for like.. https://www.tayna.co.uk/leisure-batteries/numax/lv26mf/
If you want to spend more look at Trojan who make traction batteries, these are designed for heavy use, as used on golf carts, mobility scooters etc
how much you should spend depends on how you camp, do you go on EHU a lot or not.. do you have solar.. who do you expect from a battery ?
Reactions: Jim
DFMan
DFMan
41
13
Lancashire
Toyota Dyna
Newbie
@scotjimland I hope to reply on EHU less and less in the future as the idea of Aires(less available EHU than campsites) appeals to me. I don't have solar and I hope that it can take care of all the mobile devices, lights and a 12V TV and a MiFi device.
scotjimland
2,246
9,757
A Woosh bang
In that case I suggest a new like for like battery and also look at the possibility of adding a second identical one, thereby doubling your capacity and length of stay off EHU.. see how you get on.. If needs be, after that consider a solar panel .. say 150watt to start , that will further extend the time you can be off grid..
Do you have space for another battery in the battery locker/box or close by ?
Bear in mind, if you are touring the battery will be recharged every day when you drive.. so may not need any more capacity
irnbru
13,511
31,136
Glasgow
Benimar 264
11 yrs
Good advice your being given by scotjimland.
Depending on your battery type remember to only use your battery to around 50 percent and not use it til it’s flat or you will knacker it.
I’d definitely think on getting a 2nd battery or solar.
DFMan
DFMan
41
13
Lancashire
Toyota Dyna
Newbie
@scotjimland @irnbru The battery tray is 32cm by 32cm with a height allowance of 27cm so two batteries in the same place is out of the question. This is a shame as really like the setup scotjimland has suggested.
I do feel a little silly that I did not spot the potential problem as the 12V TV wouldn’t work after the engine was switched off when I test drove the van.
Aug 6, 2013
11,950
16,556
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
That might be true but it takes a lot of miles to put even a small amount back without help from, for example, a battery-to-battery charger. Any serious off-site touring will need help from solar.
DFMan
DFMan
41
13
Lancashire
Toyota Dyna
Newbie
All done. New battery ordered. Thank you all for your help.
meanders
Funster - Life Member
2,542
8,262
Ipswich, Suffolk
C class
Since 2004
Make sure you properly vent the area around the battery before trying to connect or disconnect. They produce hydrogen and if it collects, a spark occurs and goes bang it can be spectacular.
Marquis did it to our leisure battery some years ago during a habitation check. Quite a mess as the battery case split throwing plastic shrapnel (if such a thing exists) everywhere and the engineer had a nasty cut on his face.
davejen
1,861
1,235
Preston
Given up travelling
Since 1992
Yes, there should be a "hole" in the bottom of the battery box, to let the gasses escape. You may have a thin plastic tube coming from the top/side of battery this is a breather and should be pushed through the hole to let the gasses escape to the atmosphere.
Hope this helps,
Cheers, Dave(y)
meanders
2,542
8,262
Ipswich, Suffolk
C class
Since 2004
@meanders The battery is stored externally. Do I still need to vent?
Always safest to do so. One habitation engineer I know uses a battery powered fan to force the hydrogen away once the cover is off the battery. Remember hydrogen rises in air. The pipe is not for draining it. It will drain out any electrolyte leaks but also allows some air in.
maxi77
892
560
Kingdom of Fife
coacbuilt
newbie
Hope this helps,
Cheers, Dave(y)
As the prime gas we are concerned about is hydrogen, the lightest gas which will always rise a hole in the bottom has little utility.
DFMan
DFMan
41
13
Lancashire
Toyota Dyna
Newbie
The battery has arrived! Do I need to switch off/ disconnect anything first before I disconnect the battery as described by @tacr2man ? Do I leave the battery to vent in the open first? If so for how long?
Oct 2, 2008
4,464
7,931
Salopia
Duro 6x6 Overlander
since 1968
@dfm If you havent been running anything from the "dead battery"
the chances of there being any gassing is minimal . Just disconnect the negative (earth lead ) , and retain it back out of the way . Then remove the pos lead and any fixings for the battery . Remove old battery , clean up while its out , and then fit new , reattach locating fixings . Then put on pos lead and secure . Then connect neg lead and secure fixing . Job Done , have a cup of tea :) I see from prev posts you don't have solar to bother about .
Bailey58
8,798
29,334
Norfolk and Toftir.
Sold
July 2010 (ex tugger)
And if he does have solar to think about (as I do when I get some answers before deciding what batteries I will buy)?
Oct 2, 2008
4,464
7,931
Salopia
Duro 6x6 Overlander
since 1968
If he did have solar , the solar needs isolating before disconnecting battery , as most solar regulators need the reference voltage of the batteries to control the voltage etc .
Allanm
5,431
9,192
Cotes d'armor, France
Burstner Harmony TI 736 G
Since 1987
Do you have a multimeter? The battery may have been knacker^d anyway, but you need to know if is being charged.
Check the battery voltage after you have fitted it, then start the engine and see if the battery voltage rises. If it shows around 14v, your sorted, if the voltage doesn’t rise, you may have a fault in the split charge system.
Sounds very dangerous to me, even a battery powered fan can create sparks as it’s running. He should know better...
