I hope you all don’t mind if I ask another EHU question...
We have just enjoyed a two day stay on the Honfleur Aire in France. This was the first Aire we’d stayed on, so we were a bit unsure about the EHU box.
I’ve attached a photo below, but the EHU had a 5 AMP restriction and from the diagram showing what we could and couldn’t run off the EHU, it shows a radiator under the red column. Does this means the Motorhome’s heating system, or specifically additional plug in radiators? We did try running our heating system for a short while, but it didn’t produce much heat, presumably due to the 5 AMP limit, so we used gas for the heating and water heating.
Are 5 AMP EHU’s standard on Aires where EHU’s are provided? If so, is it best to just run the heating and water heater off gas, and the lighting and battery charge off the EHU please?
Many thanks ?
Many thanks ?
