3 way fridge on gas how much will it use ?
Swift Suntor 590RL
As title I'm off EHU for the first time so am running my 3 way fridge on gas.
The fridge is working fine and I'm just wondering roughly how much gas it will use?
I work on the basis of approximately half a litre a day for a smallish fridge with ice compartment.
If you look up the manual for the model it will actually give the consumption, but I suspect that that will be based on ideal conditions.
Thanks, roughly what is that in kgs ?
Thanks very much.
Look in the manual it will give the gas consumption over 24 hours but it will depend on ambient temperature. If it's 30° will probably use at least 10% more also it will use a bit more if you have external fans fitted and quite a bit more with an internal fan but a small price for cold beer.
Fridge running on gas, hot water for showers 14kg lasts us 15 to 18 days.
Put some freezer blocks or bottles of water in the ice box, will help keep the fridge cold and use less gas.
As a guide, we have been off grid using gas for fridge, hot water, and cooking for around 20 days. I just refilled and I had used 15 ltrs of LPG, cost £15. Not bad I say. An ave of £1 a day tops, using refillable gas.
Heating is the big user.
Phil
