They are good, used them when fitting a second leisure battery and inverter. Studs are 8mm and 6mm and provide solid reliable connections if used with crimped ring connectors.
Looks good and would tidy up my battery compartment and be safer than the connectors I have now, I have quick release terminals on now although I don't take the battery out the, previous owner had it in storage so would remove the battery to charge it at home. I have the van wiring, solar wiring and an additional charger connected so I may get a couple of these
