3 refillable gas tanks?
Finch
Looking
Newbie
Is it possible to combine an underslung lpg tank and 2 gaslow cylinders into one refillable system?
I would think it is possible.
But
I am not sure when I say this but
Is there a limit to the amount of lpg that can be carried?
There certainly is on the shuttle and probably on the ferries.
But
I think DFDS limit you to 3 x 15kg gas bottles, properly secured. Not sure about the 15kg bottle size limit, though, and I last checked in 2019.
Steve
Somewhere in the back of my mind (It's a long way back)
I think the Chunnel is also 45kgs of gas.
Yes. Although having a big enough underslung and selling the gaslows will give you more storage space. The changeover valve arrangements could also get complicated. Refill valves should be easy.
Channel tunnel is 50kg total, with each tank not being over 47kg. Slightly strange choices there!
DFDS & Brittany Ferries have 47kg total with a 3 cylinder max.
Yes been there done that,no problem. Your cylinder and tank will only accept a 80% fill. The pipework will have a splitter Tank/Bottles
Just Q
Are underslung tanks fitted with 80% cut-offs?
As they are horizontal rather than vertical how do the cut-offs work on possibly a sloping forecourt? Is there not the possibility of over- or under-fill?
Geoff
Why do you ask
My Van has gas only combi (so no electric heating option on hookup) and while it is well insulated I want to be able to operate at decent intervals even in colder weather without revisiting an lpg station too often.
It’s possible I’ll pop a diesel heater in as an alternative, but I would need that to be joined into the existing ducting to heat the subfloor and stop frost protection measures activating.
Just Q
Geoff
There is but I suspect that it's accommodated within the 80%. The cut-off valve is the same type as for a vertical bottle/tank.
