Yes. I’ve just removed two to replace with gaslow. I have the two bottles available if anyone interested.Hi all is it ok to replace 2x6 kg gas cylinders with 2x 13 kg cylinders on a compactline Carthago, cheers
I have two 11kg Flogas in my locker, the 13 kg Calor is too big for two to be fitted so i keep it in the shed as a standby in time s of shortages.13Kg Calor @580mm high is a tight fit for the gas locker unless yours is a different pattern to my 2016 Compactline 138. A Gaslow 11Kg refillable is 530mm, a 10Kg Safefill 570mm. If you don't want to go down the refillable route then the old BP Gaslite/Flogas 10Kg will give you the most gas. Only exchangeable in UK though.
We used to buy bottles in France before we bought refillables.can’t refill in France so wanted to take 2x 13 kg in gas locker to be on safe side cheers
You can sign up for a free issue gas bottle from any of the nationwide supermarket chains.
We had I x Calor (left) and 1 x SuperU (right) bottle that covered all eventuality's.
Supermarket bottles in France have not been free issue for many years now, most only want a nominal 5 - 25€ now which is refundable if you take them back with the relevant paperwork
