2019 dometic fridge fans help please
Lanerboy
midlands
Carthago 4.9 superior
Hi all
I am looking at trying to fit some internal fans on the fins in my 2019 tower unit fridge.
If I remove the cooling fins do they just unscrew and pull off, I am looking to get a wire through the same hole as the thermostat cable.
Hi all
Hi,
Mal did his and I think he may have put it on the FB page.
It does make quite a difference.
Hi,
Hi Rob
Yes I know Mal did this I have read his thread and he took the feed through this hole but the only way to get the wire through is to remove the cooling fins from what I can see.
Not sure if they are on the type of fixings that trap a surface and i dont want to remove the fins and then the back part with the thread in it fall down behind the fridge, hope this makes sense
I fitted a 92mm to the fins in our fridge a few years back, really to circulate the air around the fridge for a more even temperature throughout the fridge.
Did it drop the temperature drastically, no, maybe 1 to 2 degrees C at the fan thermostat which is at the front of the fridge away from the cooling fins.
I drilled small holes in the fins and used cable ties to mount the fan.
The fan is controlled by a Chinese digital temperature controller and the cables exit via the drip tube.
The fan is not the run of the mill computer fans, bur a high CFM model.
Fridge is not on in the photo hence the temperatures on the readouts.
Ok so starting to get somewhere as i now have the cable through the fridge ready to connect to the 12v supply.
Can anyone recommend some fans for both inside the fridge and outside on the top vent, i was thinking of this one, 2 outside and 1 inside, thoughts please
Amazon product ASIN B07CG2PGY6
This is our top vent fan setup, 3 x 140mm fans that can be individually switched on or off at the fans.
Probably a bit over the top for what you have in mind.
Top vent fans that I used, high output but quiet with it.
Internal fan I used is only 14mm thick rather than the standard 25mm thick, so less intrusion into the shelf for foodstuffs.
Hi Rob
Makes perfect sense Shawn, I would like to do mine at some point.
Noctua fans a good choice in any size - they're super quiet.
I'm upgrading ours at the weekend. Can't get to the fridge side of the van in the garage. Bought some Arctic F12s. I've fitted a series/parallel switch for fast and slow modes, an SMD red LED and connector block 😎
Only uses 70ma in series mode 👌😎
This MAY be of interest to you before you get into it too far.
The problem with fitting a fan inside is that the thermostat is designed for a static evaporator and has a switch off temp of typically -5°c.
Maybe it can be turned right up to +2c I don't know what the range on them is, but left alone with a fan circulating air it wouldn't switch off until the whole fridge is frozen (probably unachievable) The fridge will run continuously and use more gas/electric. Probably why grandad sees a lower temp 😏
When this conversion is done to a domestic compressor fridge the stat needs changing to a bottle cooler type which have a range something like -2 to +11c
