2015 Boxer. Thermostat reading fluctuating
North Devon
Autosleeper Kingham
Since 2013
The cab heater sits on 'zero' then fluctuating up a couple of bars only to then drop down again repeatedly whilst we are on the move.
I assume that it could be the thermostat sticking but l'm in france a week away from returning home.
Is it ok to continue driving and accepting l've got a cold cab or can it cause actual damage to my van ?
Any advice is very welcome please.
Have you checked the coolant level?
Thank you for your swift reply.
Yes, I've just checked and the coolant level is slightly lower than minimum. I'm waiting a while for the van to cool down before topping up.
Be nice if that was the problem.
Sadly still fluctuating...any thoughts on risks whilst traveling.. hopefully l can keep going till l get back to UK?
Re reading your post you say “cab heater”. Are you talking about the engine temperature gauge on your dashboard?
Only other thing I can think of is to check the terminals/connection to the temperature sender which will be on the engine.
What temperature is it where you are?
