2015 3.0 Ducato 290 Not Cranking (1 Viewer)
Nov 9, 2012
11
3
Newtown
N+B Arto 88LE
Hi All,
I have an intermittent problem, could anybody tell me if there is a Start Relay and it’s location in the Fusebox? If not, is it incorporated in the starter solenoid and low trigger current fed directly from the Ignition Switch? When I attempt to start the engine, the dash lights come on as normal but nothing happens. I am not getting the trigger current down to the Starter Motor and wondering if it’s the Ignition Switch at fault. The immobiliser is not the issue.Thanks for any input.
JArto
Nov 9, 2012
11
3
Newtown
N+B Arto 88LE
Best to check the earthing straps and if you have jump leads use those to create an earth from the battery negative to the engine and then see if it turns over.
Thanks for the answer, I checked that first, all good as the motorhome is stored indoors.
Jul 6, 2009
1,570
1,870
Our Burstner wont turn over if the brake pedal is not pressed, last year the brake light switch started to play up and we had the same problem. Get someone to check the brake lights come on when pedal pressed. Long shot but you never know?
JArto
Nov 9, 2012
11
3
Newtown
N+B Arto 88LE
Have you checked that power is not getting to the solenoid , with the key turned to start position , with a volt meter at the starter motor ?
Yeah, no power down to the solenoid with the ignition on. That's why I'm wondering if there's a Starter Relay, or if the trigger current comes directly from the Ignition Switch?🤔
JArto
Nov 9, 2012
11
3
Newtown
N+B Arto 88LE
Just to add, it starts when I put a jumper wire from the Battery Positive directly to the Solenoid with the ignition on. Leading to my conclusion.
Oct 10, 2018
1,822
1,004
Bracklesham Bay, West Sussex
PVC
JArto I think there will be a multi-plug connecting the ignition switch wiring with the main wiring and maybe that could be worth checked, There is a 30 amp fuse described as for - Ignition switch/Starter motor - in the engine compartment fuse box ( FO3 top maxi fuse ? ) that could also be worth checking.
3,895
5,835
Rochester
Auto-Trail Mohawk
16 fun filled years
Could be the immobilisor kicking in, I have had it a couple of times and found locking and unlocking the doors sorted it
JArto
Nov 9, 2012
11
3
Newtown
N+B Arto 88LE
I will take a look later, I have a new ignition switch, so I'll fit it anyway. It appears that it may have missed the recall in 2016 for it to be replaced. It's starting at the moment without problems but as it's intermittent, I don't have much confidence in it!
JArto
Nov 9, 2012
11
3
Newtown
N+B Arto 88LE
no power at the starter motor so next check would be is there power at the back of the ignition switch
Going to look later, as mentioned it is intermittent, going to check later. Thanks
Aug 18, 2014
22,562
121,260
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
ignition switches used toi be a problem years ago.Mine used to do it. I just kept a length of wire for when it tried to catch me out in fuel stations. & start it with that.
JArto
Nov 9, 2012
11
3
Newtown
N+B Arto 88LE
I did read that somewhere, was going to change it out but can't replicate the problem now! Starts every time at the moment!🤔Thanks 👍
JArto
Nov 9, 2012
11
3
Newtown
N+B Arto 88LE
Hi, had a further look today. Fuse 03 is for the Main Supply to the Starter Motor and was good. Checked pin A3(Brown/Grey) on Ignition Switch through a connector down to the Starter Solenoid Relay via a Brown/Black wire. This is the trigger wire. Resistance <1 ohm so all good. There is no other relay in the Ignition Circuit as it's in the Solenoid. Reassembled and started numerous times as normal at the moment. Problem seems to have disappeared for the time being! Just leaving this here for reference. Thanks to you and everyone else for your suggestions.👍
newbee
17
14
swift bessecar 562
I had this exact problem… it was a simple remedy of tightning the battery clamps
JArto
Nov 9, 2012
11
3
Newtown
N+B Arto 88LE
Thanks for your suggestion, I checked the connections on the clamps before my other checks. They were all tight and clean.👍
Dec 12, 2010
5,215
21,059
Cumbria
since 2011
The ignition switch on the Iveco would turn all the way, but sometimes wouldn't crank the engine. I flooded the switch with about a quarter of a can of GT85 spray, working the key vigorously between applications. There was a lot of muck that came out in the spray spillage, but the problem has not come back.
