Have you described that correctly? You lift off on the accelerator and you get a whirring noise. Depress the clutch, presumably with foot off accelerator, and the whirring vanishes?Hi all, when you let off the accelerator in 5th & 6th gear I get a whirring noise from the gearbox. It disappears when putting the clutch down. Can it be fixed or is it a case of living with it, is it causing any damage, how long will it go on? It’s a pvc with 90k. Tia.
+1Hi could be be worn thrust bearing in clutch assembly ............. cheers Ian
+2Hi could be be worn thrust bearing in clutch assembly ............. cheers Ian
Yup - thrust bearing!
Judging by the op avatar the van in question wears the "diamond of doom" (it's a Renault) and has six forward gears. The under lubricated fifth gear issue you allude to was generally considered to be a failing in Fiat/Shitron/Peugeot vans of the x230 range (1994-2001).a classic sign of the 5th gear running dry and beginning to fail. cheaper to get it fixed now when you can choose where to get it fixed
apologies, not got my glasses on to see the dodgy diamond in the avatarJudging by the op avatar the van in question wears the "diamond of doom" (it's a Renault) and has six forward gears. The under lubricated fifth gear issue you allude to was generally considered to be a failing in Fiat/Shitron/Peugeot vans of the x230 range (1994-2001).
D.
No worries mate.apologies, not got my glasses on to see the dodgy diamond in the avatar
Sorry, old picture, old van. I did state at the top what year and it was a Citroen. Thanks all for the info. Sounds as tho it’s going to be expensive. Maybe cheaper in the long run for a recon box?Judging by the op avatar the van in question wears the "diamond of doom" (it's a Renault) and has six forward gears. The under lubricated fifth gear issue you allude to was generally considered to be a failing in Fiat/Shitron/Peugeot vans of the x230 range (1994-2001).
D.
My apologies, yes you did. Being a 2008 makes it x250 and my comment regarding the supposed poor lubrication of fifth doesn't apply to this gearbox. It is almost certainly a bearing in the box failing so the sooner you get it done the better.Sorry, old picture, old van. I did state at the top what year and it was a Citroen. Thanks all for the info. Sounds as tho it’s going to be expensive. Maybe cheaper in the long run for a recon box?
Not these days: release bearings are run with zero clearance & preferably a light pre-load to prevent rattle and finger wear.A worn thrust bearing may rattle a little if it's badly worn but will only whine and whirr when under load....ie: pedal down....and if properly adjusted, until pedal pressure is introduced it will barely be turning.
Hi Dave, is this something you could rectify with the gearbox? I was going to get in touch about a price for cruise control and think maybe get both done at same time?
