- May 19, 2018
- 246
- 390
Hi, hope you're all well in these trying times.
As we're all locked down, we decided to wash the van this weekend and then pretend we were away in the back garden.
I started the van as I needed to move it to get at both sides. It's not been started since January and I'm pretty sure it has heater plug problems. It started eventually however.
The problem is, the wipers, washers and rh indicators are all operating, without me touching anything. I started removing fuses once I found out which does what and where they're hidden. Can't find a fuse for the indicators and can't find the relay either even though I can hear it.
While playing with the stalk hoping the problem might magically disappear, I turned main beam on, which would then not turn off!
This leads me to suspect something under the cover of the steering column but have neither the knowledge or inclination to start playing around in there.
Anyone had similar issues and found an easy fix?
The van is an Auto Trail cheyenne se 640.
Alan
Alan
