DaveLud
- Sep 21, 2019
- 5
- 3
- Burstner Delphin
- Since 2011
Can anyone advise please. My 2006 Burstner Dephin T700 largely performs quite well, but I have a problem with the long 12v fluoresent light in the main part of the living area:
- It usually switches on OK.
- After a variable amount of time it either goes out completely, or mostly, leaving a glow at either end of the tube.
- It shares a switch mounting with the exterior light. If I switch that on at the same time as the flourescent tube, the tube behaves as above. If I switch other 12v lights on, the tube sometimes behaves as above. If I switch other mains fittings on, the tube sometimes behaves as above.
- If I then switch the tube off, and the other fitting off, wait 30 seconds or so, then switch the tube back on, it usually comes on OK, at least for some time.
- Putting in a new tube makes no difference. If it were a domestic fluorecent light, I would change the starter, but on this design, I cannot find one.
- It seems like a voltage regulator problem, but I cannot find a v-r on the wiring diagram.
ANY IDEAS PLEASE?
