We have the bessacarr and it should be the same. What exact measurements do you want, happy to help.
That will depend on
1, What base vehicle was used
2. If standard chassis was retaind or Alko chassis added
3 Front / Rear or both
4. How critical is the measurement?
If your building a trailer to put it on = Critical
If your laying slabs to park it on = Its not
The more we know the better the answer
G
Well the very least info required would be what the base vehicle is...
I will go out and measure one tomorrow for you.. I am sure I can find a Ducato somewhere around here
Same track across all variants...tyre center to tyre center.
1810mm front
1790mm rear.
Standard Fiat chassis.
ALKO rear chassis is wider.
Gawd knows why they bother with a 20mm difference.
Just to piss you off John, it needs confirming.Cheers PJ, saved me crawling around tomorrow !
Ya bugger !!! Ok.. no worriesJust to piss you off John, it needs confirming.
Google never listed a year so could be different
1720mm front, 1740mm rear ( between centres )
That is from a 2002 Swift motorhome on a Ducato chassis
