- Jan 19, 2020
- 2,021
- 16,584
- Downsized to Bongo!
- Since 2012
On most Motorhomes I would agree but on the 3 Hymers we have had the first 2 were 30 kg under current one 16 kg over.The brochure payload and the true payload will bear no resemblance to each other.
Many thanks. I found the original import documents. 'Empty weight' is 3060 kg.
Oi!Still don't rely on it. Motorhomes are like people, they gain weight over time. Take it to a weighbridge.
Oi!
Have you been following my profile?
Going to be very tight to run at 3500.Many thanks. I found the original import documents. 'Empty weight' is 3060 kg.
Doesn't that mean you are restricted to lower speed limits as you are over 3050 unladenMany thanks. I found the original import documents. 'Empty weight' is 3060 kg.
No problem for me I follow the trucks!Doesn't that mean you are restricted to lower speed limits as you are over 3050 unladen
