135 degree alu extrusion? (1 Viewer)
vantastic
69
26
Crafter xlwb
I am using 15mm furniture board in my van build and I've hit somewhat of a road block there one part of my layout involves 2 45 degree angles to form the corner, cutting a corner if you will. See if I can draw a pic:
Code:
    __
I need to join the boards at 135 degrees. The outside edge will be exposed and it's a high traffic area. Had it been a 90 degree angle I would have used alu extrusion for the join, brilliant stuff, simple to use. But I haven't come across anything to a 135 degree angle.
Anyone know if a 135 degree extrusion that can be used for this application can be got? Or are there perhaps other thingys I could use instead?
V
vantastic
69
26
Crafter xlwb
That looks like the job!
Thank you! ?
