- May 26, 2022
- 12
- 3
- Wildax Solaris(2011)
- Since 2012
Hello,
my first post so please be gentle.
Looking for advise on fitting a new Thetford fridge!
We have bought a new Thetford N4090 fridge for our 2011 Solaris. We have successfully wired the 240v and piped the gas and both working fine. However, when trying to get it to run on the engine (via the leisure battery I believe), the 2 LC wires that feed the electronic fridge controls switch off when the engine starts, so fridge turns off.
The LC feed (to the fridge) is activated from the control panel in the van, switching on the main switch on the control panel activates the 12v lights, water pump and fridge). As mentioned above once the engine is running the 12v feed goes off. This can be also confirmed at the control panel as the main switch remains in the on position (with a green light still illuminated) but the rear interior lights go out and the water pump no longer operates. Lastly when this all happens the "G" lights up on the control panel display indicating the leisure battery is charging from the alternator.
We are running a DS-300UK distribution box and having read the manuals it suggests a couple of options that we have tried.
1. Remove the 3A fuse in position 6 which "gives power to the cutting out device of all 12v mains during the trip, except the 12v refrigerator"
The result of removing the 3A fuse is the LC supply now remains on when the engine is running, (good) however it appears to cause the HC feed to go intermittent. On inspection in the Dis. box there is a Relay that is now active causing this HC switching. (?)
2. Location 12 on the Dis. board, where there are 2 male connectors:- Described as AES Fridge connection. "It is a bridge which excludes the 3 way fridge function and is used to connect the AES fridge directly to the B2 (which is the leisure battery)
The result of the bridge appears to be that HC supply now is constant at 12.2v when the engine is off, but the LC feed still drops away once the engine is started.
Essentially the root of the problem is the LC feed being cut once the engine is running, this probably wasn't an issue with the old fridge as there was no digital controls as such which likely meant that losing that feed when on the move was not a problem.
hope this makes some sort of sense and there may be some ideas on how to resolve
thanks
thanks
