Take care
You could die of thirst while waiting!
Can't you use the gas?
That's what I use , I picked up a great one in asda a few weeks back for £4 and an insulated mug for £1Get yourself a decent insulated flask, Lidl had them a few weeks ago for 8 quid they keep water hot enough for drinks for over 8 hours.
I can't see a situation when I would run out of gas, I always top up when the first bottle is empty and if I was that desperate I'd knock on the door of the next van.
Had to do that in France when my bottle opener broke - far more serious.
We use one of those a lot, amazing for 12 quid work far better than the expensive Smeg hob in the van.We have a back-up gas hob and some canisters (see below) which can also be used outside to cook smelly/messy stuff if needs be, or supplement the 2 ring hob if needed ... it is powerful so can boil a kettle very quickly ... no way could I wait for an electric 12v one to boil ... I'd end up with withdrawal symptoms!!!
Yup, the Smev hob is usually 1.8kw max for the largest burner whereas these are often 2kw and it really does make quite a difference.We use one of those a lot, amazing for 12 quid work far better than the expensive Smeg hob in the van.
Obviously, Dometic/Smev use different kw's to rest off us.Yup, the Smev hob is usually 1.8kw max for the largest burner whereas these are often 2kw and it really does make quite a difference.
Gas for these cheap at B&M. Surely the 12v kettle must be an early April fool?We have a back-up gas hob and some canisters (see below) which can also be used outside to cook smelly/messy stuff if needs be, or supplement the 2 ring hob if needed ... it is powerful so can boil a kettle very quickly ... no way could I wait for an electric 12v one to boil ... I'd end up with withdrawal symptoms!!!
Yup, 4 canisters for £3.99 at B&M, much cheaper than any other shop/outlet except car boot sales where I got a load and it worked out at 30p each!Gas for these cheap at B&M. Surely the 12v kettle must be an early April fool?
Not sure if want to drive along with a kettle full of water either
A 12v element inside a flask would be a good thing. With little heat loss it would boil a lot faster. The top would need a vent of course.
I have one of these too, runs on Butane - absolutely useless at negative temperatures (I do a lot of rallies in the mid of winter).
No not at all, as I mentioned earlier it is a contingency. It is small, compact and is there if I ever need it. (If I run out of propane and have no EHU!)
Jeez. I am getting to the age now where I would have forgotten why I put the kettle on in the first place30 mins to boil 750ml of water - haha
No way can I wait 10 minutes for a coffee. When I want one I want one now....You can get it down to 10 mins if you boil enough for just one cup, I'm selfish so that suits me
Probably be quicker to fill a metal container with water and rest it on the exhaust manifold.
I'm guessing it takes a lot of current (10A+) in which case be aware the lighter plug could get very hot if the connection isn't perfect. It may work perfectly to begin with but once the connection isn't perfect things will get hot and then it goes downhill from there. The contacts soften and the plastic plug can deform. Been there, done that, as they say.
There are other types of connector available which are worth considering.
It's not the wiring which gets hot but the problem is the points of contact between the plug and socket. The metal bits get hot and become softer making the problem worse. When it's all clean and new it will be fine, it is when things get a bit older when issues might appear.The 12V socket is wired directly to the battery via 6 AWG cable, I have placed a 20A fuse inline (just in case). I am not worried about the wiring.
I constantly touched the 12V socket and felt the wiring during the boiling of the kettle for sanity
It's 200W @ 12V so closer to 17 A
If you find you have problems there are flat pin plugs you can get and there is a smaller version of the classic cigar lighter known as a DIN plug. The latter is what I changed to after problems running a compressor coolbox from a cigar lighter socket.
Sorry, I thought you had it connected using a cigar lighter socket and plug.Understood, the 12V coffee maker is wired directly (I cut off of the 12V plug). I didn't want to do this with the 12V kettle as unplugging it and moving it to a water source is easier when it is just plugged into a socket. I have an infrared temperature sensor so will keep my eye on it, if it starts to melt/warp etc. I will just end up hard wiring it and filling from a bottle etc. (Anyway, it is a backup and should rarely be used).
I also have a spare DIN socket
