12v - Is this normal? (1 Viewer)
juleshe
82
42
Hampshire
Van Conversion
Since 2009
We recently purchased a german PVC and all is good. However, I have a query regarding 12v charging. Whenever I plugged in a USB adapter or an adapter plus power lead the 15amp fuse would blow. If I attached the device (phone, USB light etc) to the power lead and adapter and then plugged the whole thing in everything was fine and charged OK. The same with unplugging so if I detached my iPhone from the power cord while still plugged in the fuse would blow but if the adapter was removed first all is ok.
I should say that the USB to cigarette adapters that I have are good quality ones with many good amazon reviews.
Its not too much of an issue as long as I remember, which I frequently don't, so carry a number of spare fuses.
Any idea why this would happen I don't remember having the same issue with our previous vans.
Thanks in advance.
Jules
juleshe
juleshe
82
42
Hampshire
Van Conversion
Since 2009
Yes. Same on every device and different leads and using 2 different adapters.
Jan 19, 2014
9,386
24,755
Derbyshire
Elddis Accordo 105
since 2014
Just check the polarity on the socket. The socket is the only common thing if you've swapped leads/adaptors etc. I'm thinking maybe a protection diode is taking the fuse out?
juleshe
juleshe
82
42
Hampshire
Van Conversion
Since 2009
Sorry for my naivety but how would I check the polarity?
Jan 19, 2014
9,386
24,755
Derbyshire
Elddis Accordo 105
since 2014
With a multimeter set on dc volts. The centre contact should be positive. If it's the wrong way round the multimeter will show - 12v
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
Physically check the plug and socket. I can't imagine a fault that would cause the symptoms you describe but I have come across plugs that short circuit the sockets as they are being inserted and removed. Once in they're OK but as they are moved in or out the earth 'leaf' of the plug causes problems.
Jun 30, 2011
7,234
20,096
Barnard Castle, UK
Concorde Concerto
What PVC did you purchase, I do like the German ones.
Any pics?
juleshe
juleshe
82
42
Hampshire
Van Conversion
Since 2009
Could be but I have 3 12v sockets in the living area and I think it happens with all three. Will check though.
juleshe
juleshe
82
42
Hampshire
Van Conversion
Since 2009
Any pics?
Westfalia Amundsen. No pictures at present I'm afraid. Super van, all the details are very well thought out (like Truma diesel heating so extra storage in the rear garage).
GWAYGWAY
4,213
3,306
Dover
Hymer ML I 580
4 years
Are you using the correct socket as my car did this to me every time I used the socket for a charger but OK with the supplied lighter. turned out the earth and power bit were very close and the wobbly socket touched both. Good quality socket cured it.
43,323
49,440
Don't care how many good reviews the socket adaptor has, you have a bad one.
plugging in the lead appears to be causing a power surge
Plugging in the lead AND appliance together the appliance is absorbing the power surge.
Jan 19, 2014
9,386
24,755
Derbyshire
Elddis Accordo 105
since 2014
2 different adapters though pappa, it's very odd.. Maybe try a third if the first 2 are the same make?
juleshe
juleshe
82
42
Hampshire
Van Conversion
Since 2009
These are the two different adapters although the second one seems to be a newer version of the one i have:
Amazon product ASIN B00KPUM558Amazon product ASIN B012NO14M8
Lenny HB
53,420
149,939
On the coast in West Sussex
Hymer B678 DL
I've had that happen with poor quality Hella plugs, its a German van and he is using an adaptor in an adaptor so sounds like Hella sockets.
PeteH
6,853
9,030
East Riding of Yorkshire
Rapido, 999M.
18+yrs plus 25+Towing
I think I go along with Papa. Adapters have a small circuit board inside to reduce and stabilise the charge voltage to about 5Volts (USB). To blow a 15 amp fuse on 12V (nom) you have to draw momentarily in excess of 180W of power (toast anyone?). That IMV can only be an issue with the control circuitry of the adapters. When you add the Device It`s circuitry is coping with the surge and will continue to until it decides that it too has had enough and fries!
EDIT:- I have a couple of adapters which have 2 distinct settings, one is general the other is label`d "A" and is for Apple devices they won`t charge on the other setting.
juleshe
juleshe
82
42
Hampshire
Van Conversion
Since 2009
Showing my ignorance again as I'm not sure what a Hella socket is but here is a photo of our socket:
PeteH
6,853
9,030
Rapido, 999M.
Hella sockets have a "clip" on the Positive pole which holds the Positive pole of the plug not relying on the friction an "goodwill" of the outer (negative) case of the traditional "Cigar" socket.
43,323
49,440
The Hella plugs and Sockets are a different size and slightly different shape to normal cig lighter sockets.
Hella type will not fit the other without an adaptor ring on the Hella plug.
BKen
55
30
Rojales Spain
Low Profile
Since 2000
If its a German van then somebody has changed the power sockets to UK type in the picture ..somebody has had the sockets off you need to check the wiring behind them has not been distrubed .as for the difference between Hella DIN plug (on the Left) and normal cig lighter plug(on the right ) the picture belows shows it.your pic shows a normal one
I would check the wiring here also as German van would come with the Hella Din Socket and plug....oh Pappa and Pete beat me to it
juleshe
juleshe
82
42
Hampshire
Van Conversion
Since 2009
If its a German van then somebody has changed the power sockets to UK type in the picture ..somebody has had the sockets off you need to check the wiring behind them has not been distrubed .as for the difference between Hella DIN plug (on the Left) and normal cig lighter plug(on the right ) the picture belows shows it.your pic shows a normal one View attachment 193433 View attachment 193434
I may be wrong but I would have thought Westfalia vans built for the UK market would have left the factory with UK style sockets fitted.
Lenny HB
53,420
149,939
Hymer B678 DL
That is a standard cigarette lighter socket a lot of German vans have now changed to from the Hella.
I made an incorrect assumption as it sounded like you were plugging an adaptor into an adaptor.
Aug 22, 2017
829
1,946
Wildax Europa PVC
Since 2014 -- cycle-camper before that
I think this is an increasingly common problem. If you closely examine 12v sockets normally fitted to habitation areas and compare them with those typically found in vehicle cabs, you will see the designs differ quite significantly. (Just to clarify we are not talking about Hella sockets here, just the standard 12v socket used most places outside of Germany).
On the sockets found in cars and van cabs the positive terminal is usually just in the very base of the socket, whereas on the type fitted to habitation areas the positive terminal usually extends some way up the inside of the socket, leaving a small gap between negative and postive terminals. Some 12v plugs will work fine in both but some, designed specifically for the type of socket found in cars, will short across the negative and positive terminals. I have found this to be a particular problem with USB adaptors: I looked at a variety of them and found that at least 75% would likely cause a short circuit.
In my own van I replaced the 12v socket in the habitation area for a design that matched those found in vehicle cabs. Now all my adaptors work fine without shorting. If you only ever use the socket for USB power, you could instead replace with a USB socket: the range of modular sockets includes a twin USB module.
Aug 22, 2017
829
1,946
Wildax Europa PVC
USB modular socket
maxi77
892
560
Kingdom of Fife
coacbuilt
newbie
Whilst a dodgy wiring at the back might cause this it sounds unlikely. A normal usb charger should not blow a 15A fuse on load or not. My first Check would be another usb charger, and some other 12 v device to see if your problem is related to one appliance or to all. If everything blows the fuse then it is a wiring problem most likely.
Glandwr
Banned
Jul 10, 2014
1,057
3,301
the Berwyn Mountains
Hymer S740
since 2009
That theory could be tested by wrapping a piece of insulation tape around the bottom of the usb adaptor that would cover the bottom third of the 2 spring neg contacts and giving it a jiggle if you see what I mean
juleshe
juleshe
82
42
Hampshire
Van Conversion
Since 2009
Some interesting theories. Many thanks to all who have made suggestions. I’ll try a few out over the next few days and see how we get on.
