12v heavy duty compressor (1 Viewer)
43,323
49,420
just been pointed to this item by supermike over on sister site RVOC.
Link Removed
delivered this morning and looks the dogs do-da's.
very similar (if not the same one) to the ring RAC700 unit which has very good reviews.
only a couple in each branch so be quick for a bargain.
Road Runner
1,143
1,445
Europe
yes
Since before Motorhomefun
I had hell finding place to pump my RV tyre up as no where had pumps for HGV on forecourt and burnt out endless cheapies.
My pump cost £32 so this is a great priced pump.
Good link Papa J:winky:
Snowbird
11,818
22,346
Liverpool.
Fifth wheel.
Since 11-05-2000
Got it, mine burnt out just before Xmas so this came just at the right time.
Looks quite substantial:thumb:
Road Runner
1,143
1,445
Europe
yes
Is this a first?????????????????
Snowy bought his an hour after the link was posted:whatthe::Doh:
Mind you maplins is only down the road for him:ROFLMAO::ROFLMAO::ROFLMAO:
Apr 27, 2008
11,842
14,071
Eastbourne East Sussex
Hymer low profile
Since 1972
I bought one of these some months back. The drive to the piston sheared after using it twice, which is worse than the £5 ones. I suspect its robust appearance may be an illusion.
I have now invested a bit more in a Ring one which so far has been OK.
Hope you find them more satisfactory than I did.
43,323
49,420
just used it on the volvo's tyres...havent done them for ages :Doh:
fronts 36psi...was 25psi
rears 32psi...was 22psi
around 2 mins per tyre.
might get a better mpg now. :thumb:
not bad for a small compressor.
too dark to do the RV and i need a 12v extension lead first.
fronts are near enough but the rears are 7mtrs away from the fag socket :Sad:
scotjimland
2,309
9,978
A Woosh bang
I gave up on 12v compressors.. yes, I know they are handy and don't need any effort but a twin barrel foot pump is more dependable ..
and it keeps Jan fit :thumb: :roflmto:
43,323
49,420
Like you Jim, i have an aversion to them too and have a small mains fired compressor (Aldi special)in the garage but its fixed and a pain running hoses out to the RV.
figured this will do for top-up's :thumb:
scotjimland
2,309
9,978
A Woosh bang
I was fortunate that the RV had an air compressor and tank, so bought an airline and gauge and used a spare take off point on the tank. ..
Only ever used it in anger once. I snapped a valve stem, :Doh: had to remove the tyre and fit a new one .. this was on an aire miles from any garage .. A foot pump or a 12 v compressor would have been useless to reseal the tyre to the rim..
I was surprised how easy it was to remove a 22" tyre .. I was expecting a fight but it was no match for a 2lb lump hammer .. :roflmto:
Feb 27, 2011
14,732
75,877
UK
Self Build
Just ordered one. Then saw the post about the one that broke :Doh:
Should have read to the end of the thread before ordering lol
Snowbird
11,818
22,346
Liverpool.
Fifth wheel.
Since 11-05-2000
Don't worry Gromet, mines still going strong 9 months down the line and I use it at least once a week. Its great for blowing up the air assist suspension as well as tyres.
Jul 28, 2010
1,710
617
The world
Small car
try parking your volve next to the RV and run your pump from that
no need for 7mtr extension leads :Eeek::thumb:
43,323
49,420
In a moment of madness i made up an extension lead but forgot one important factor..... VOLTAGE DROP :Doh:
the compressor pumped about as fast as i could pump a footpump :Blush: bop......bop.....bop.....bop.....bop
i now use a small 17ah wheelchair battery and the compressor works fine for topping up pressure in both the tyres and air assist suspension.
Les
Apr 18, 2008
301
4,114
Seaford
Low Profile
i bought the Ring compreser (not sure model No) it has crocodile clips on as to much load on cigarette lighter socket god bit of kit so far
Scout
3,959
121,134
South Yorkshire
chic c line
12 years motorhoming, a lifetime of living
cheers mate, got one resevered for collection
Feb 27, 2011
14,732
75,877
UK
Self Build
Mine arrived this afternoon, connected it to my totally flat tyre and all I can is WOW!!!!! :Eeek::Eeek::Eeek:
Fast and brilliant. Burnt myself on it though 'cause like a typical bloke didn't read the instructions..... Thought the handle on it was just to protect the dial or to look pretty. It's not......:Doh::Doh::Doh:
NEV3
30
North East Wales
RV
Since 1996
I bought the Ring version 4-5 years ago and still going strong. If this one is up to the same standard then it is well worth the money. Mine cost considerably more than £17.99.
Only problem I had was the relief valve blew off before I could get my tyres to the required pressure (80 p.s.i.). Phoned Ring for advice and they didn't know what I was talking about!? Eventually figured it out for myself and adjusted the relief valve to blow off at 85 p.s.i. that way I can't over-inflate by too much! Been working great ever since; quiet too! Does get a bit warm though.
NEV3
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
i use a gast compressor 24volt. had a 12volt on the vwlt. bit expensive for just pumping up tyres but makes my air brakes work fine on the trailer. have a take off for tyres etc. darent go playing off road without one. nothing strange to get four punctures a day if running through the desert. thorns get in never find them but holes like pinholes. pump up, stick chewing gum style repairs in work a treat .
