David Aldred
- Oct 14, 2017
- 4
- 0
Hi, I have a problem with wiring and wondered if anyone has had similar.
When running off leisure battery the control panel display is dim and volts reads 5v. Battery is at 12.5v. Checked voltage at back of panel, 12v when panel unplugged, 4 volts after connecting.
Verified panel is ok by running "new" positive lead straight from battery and all ok. I then measured resistance from +ve battery connector to panel and getting 3000 ohms, i think this is where i am losing the voltage when i plug panel in.
There are 2 +ve leads in the battery compartment that join together somewhere in the van, the resistance between these is 0 ohms but from either of these two wires to the control panel is 3k ohms so i need to find out where the 2 +ve wires in the battery box join the 1 positive wire going to the control panel, because i expect a loose/dirty/faulty connection any ideas? Driving me mad. Thanks. All works ok on mains.
