12v Cab Socket not working (1 Viewer)
May 5, 2014
671
169
Leicestershire
Beginners, got Doggy the van - March 2014
Help Please from all you cleaver Funsters.
Fiat Ducato 2012, 12v Cab Power Socket (not the cigar lighter) stopped working,.
Checked 15A Fuse and it's OK. What else can be the problem?
Dogsense
May 5, 2014
671
169
Leicestershire
Thanks Peter, I swopped fuses but still no power in the socket.
Badknee
7,406
411,687
notloB
Vantage Neo
Living the dream.
How are you testing the socket? If you are plugging something in it may be the fuse in the plug, it will have one, test with a meter to a good earth. :)
CWH
5,137
247,344
WildAx PVC
From November 2013
Sorry, can't help, but can sympathise - we blew all 4 12 amp sockets in the MH (rogue satnav) & it's a real sod getting at the fuse box under the hood for the ones in the cab!
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
Where does your manual say the fuse is?
On my 2008 both sockets are on fuse 44 20amp, fuse box in cab drivers side
Techno
Jul 28, 2010
15,475
20,756
May 2010
Google tells me that yes it is the engine compartment fuse box
F14 should be 15A and F15 10A. Power and cig socket respectively.
MattR
4,096
38,471
Beds
Panel van
Years
Do you have a circuit breaker on your van? We've tripped ours when moving items in the cupboard where it is located and lost 12v power to a couple of sockets.
Dogsense
May 5, 2014
671
169
Leicestershire
I plugged a phone charger in the cigar lighter wich worked then in the power socket and not working.
Used the horn fuse (also 15A) instead of the socket fuse - not working. Put the socket fuse in the Horn - working. So not a fuse fault.
Need to get a Multi Meter. Any recommendations?
Dogsense
May 5, 2014
671
169
Leicestershire
Yes I checked the F14 fuse wich according the manual is the power socket fuse.
Sep 23, 2013
2,583
8,736
Lincs
Globecar Campscout
Don't rely too much on the manual. The fuses for my two dash sockets are the opposite way round to what the manual says.
Dogsense
May 5, 2014
671
169
Leicestershire
TheCaller, you been right, the two sockets, on my cab are opposite from what the manual says. The 10A fuse for the Cigar Lighter was the faulty one. Problem solved.
Thanks all for the advice.
Dec 11, 2011
839
2,102
Nr Hastings, East Sussex
AutoTrail Tracker RL
since 2010
I know this is an old post but I blew the fuse on one of the 12v sockets in the cab today and the advice about not relying on a visual inspection of the fuse saved me countless hours of faffing around looking for another cause. I put my meter across the fuse and lo and behold it HAD blown even though it looked fine.
Thank you!!
