12 volt while driving (1 Viewer)
TCG
Jul 6, 2017
1,357
2,041
Salford Priors
Autotrail Delaware
hi all
I don't now if i have posted this in the correct place, so please move if appropriate.
the 12 volt electrics turn themselves off when i start the engine, ideally i want to have a cool box for the beer in the garage, Is there an easy way of disabling this function to allow the 12 volt to be always fully functional
thanks in advance
43,203
48,797
Yes there is...sort of.
You need to locate then bypass the relay which controls this function.
Where is it ?.....absolutely anywhere but usually near the 12v fuses.
Lenny HB
52,684
147,589
On the coast in West Sussex
Hymer B678 DL
You can just disconnect the wire that feeds the relay that contols it, I take you have a Sargent distribution unit and the relay will be on the PCB so easier to disconnect the wire before it gets to the relay. After doing so do check that the alternator is still charging the leisure batteries in case they use the same wire, if thats the case you may have to do a mod on the pcb.
TCG
TCG
Jul 6, 2017
1,357
2,041
Salford Priors
Autotrail Delaware
Thanks Guy's. i will give Sargent a call, as their customer tec service is normally good and they should be able to tell me the location of relay
TCG
TCG
Jul 6, 2017
1,357
2,041
Salford Priors
Autotrail Delaware
If you have the common 3-way fridge it is powered with 12v when the engine is running, so you could tap off that feed and run a cable to the cool box.
Geoff
excellent Idea... Thanks
Apr 27, 2008
11,788
13,944
Eastbourne East Sussex
Hymer low profile
Since 1972
Geoff
Trouble with that is that the 12v feed to the fridge goes off with the ignition so would have to connect the coolbox elsewhere to keep it going.
A use a coldbox for beer as more than a couple in the fridge causes moaning from swmbo. My 12v doesnt go off when moving as not a British one.
In the winter sometimes have an electric blanket on when driving. Nice warm bed on arrival.
TheBig1
17,509
42,755
the issue that leaving the 12v on to supply a coolbox is that if you dont unplug after driving it will flatten your battery
Aug 18, 2011
12,090
17,892
derbys
AUTOSLEEPER SYMBOL
Sympathy with you,,my wifes the same,,she insists the 3 way fridge is only for food and white wine,,,Treated myself to a small Waiko compressor chest fridge,,brilliant.BUSBY,,
PeteH
6,853
9,029
East Riding of Yorkshire
Rapido, 999M.
18+yrs plus 25+Towing
Geoff
Ditto, Beat me to it!. But check the fuse and cable rating is up to coping with both.
Jul 5, 2013
11,713
13,681
Since 2013
This problem is very much a British built motorhome thing, as the NCC "rules" say that the 12V habitation circuits must be off when you are driving. Of course that may be sensible for caravans, not motorhomes, but the rules are the same for both. The 12V habitation circuits in European built motorhomes remain live whether the engine is off or on.
motorhomer
680
418
South Shropshire
Van Conversion
since 2005 (but 30 years caravanning)
I have a similar problem with our Autosleeper, whose 12v circuit goes off when the engine runs. My van has tank heaters in the underslung water tanks (which are actually pretty useless unless you are on mains as they flatten the battery very quickly). But I would sometimes like them on while driving - eg in France last week when it was minus 6 at midday! I can see no way of doing this. This is a serious disadvantage in what is otherwise a warm and cosy van!
