12 volt Socket (1 Viewer)
Sep 10, 2017
425
940
I want to add a 12 volt socket to run a Fiamma Turbo fan near our bed. There is a junction box for a LED light in just the right place which is on 10 amp fused circuit. I haven't checked yet what else in on this lighting circuit, i know two USB sockets are on it. Is there any reason not to simply connect to this? The fan information states:
DescriptionTurbo-Kit
Tension12V
Min. electric input0.20A
Max electric input0.33A
Max air flow7.2m3/min
Fan diameter24cm
Fan Speed2
Weight1.3kg
The Van is a 2018 Globecar Campscout Revolution if it helps with the question.
Thanks in advance for the help.
Apr 27, 2008
11,703
13,628
Eastbourne East Sussex
Hymer low profile
Since 1972
As it claims to only draw 300mA there should be no problem. If you have replaced all lights with LEDS there will be a fair bit of surplus capacity within the 10A fuse rating.
My lighting circuit was rated at 20A because it had about 20 halogen lights on the circuit, now all LED.
