1000W 240V pure sine wave AC power inverter for 24V battery (2 Viewers)
53,421
149,945
Inverters that run off 24v are common used in truck cabs as trucks are 24v.
Most of us with inverters have 1000-2000 watt inverters running ogf that size battery bank, mostly not used for long but at full power 1000 w one would take about 90amps.
Aug 18, 2017
242
766
Antequera, Spain
Adria Coral 680 SP
5 years and still learning
@ShiftZZ .... thanks for posting that link :)
I was looking for a 300W - 12V Pure Sine Wave Power Inverter to run my laptop when no ehu.
They have one on sale for £68 which is good for pure sine wave.
Mr Chrysalis
2,367
317,714
Rapido 890F A Class
Since 2016, caravans before that, folding Caravan, tents before that
https://www.sunshinesolar.co.uk/pro...5yPXGRq9xd9ZvkoTmlZnCh4pgv7kMLNcaAqZ1EALw_wcB
Just seen this...
24v? How would you wire that up in a Motorhome..
How long would 2 x 110amp batteries last pushing out 1kw?
Well, I guess IN THEORY, you would connect the two 12V batteries in series to give you the 24V supply needed, but as they are normally connected in parallel to 12V inputs and outputs, it’s probably not practical. I guess a series of relays could simultaneously make the 24V circuit whilst breaking all the 12V ones. Sounds like a good question for a Physics O level paper!
Jan 28, 2008
10,116
18,382
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
no need to break any circuits you can run 24 and 12v of the same pair of batteries we used to run race cars that way only using the 24v for the starter
Apr 27, 2016
6,872
7,992
Manchester
A class Hymer
Since the 80s
One 110amp-hour battery (12 volts) holds 12 x 110 = 1320 watt-hours = 1.32kWh
So obviously two of them will hold 2.64 kWh.
In theory they would push out 1kW for 2.64 hours, but in reality (a) the conversion is usually less than 90% efficient, (b) you won't want to drain the batteries much below 50% and (c) at high amp rates the capacity is reduced from the advertised value. So I wouldn't use it more than half an hour on a regular basis.
But that's OK for hairdryer, microwave, that kind of thing. Not much good for extended loads like air-conditioning or heating.
24 volts? Just don't go there! Sure, it's possible. But Unless you're doing it for the entertainment value, it's cheaper to throw a 24 volt inverter away and buy a 12 volt version. Unless of course you have one of those massive rigs that has truck-style 24 volt electrics already.
Apr 27, 2016
6,872
7,992
Manchester
A class Hymer
Since the 80s
How do you do that? Do you leave all the 12V circuits connected to one battery, and disconnect the second battery to hook it up in series?
Aug 18, 2017
242
766
Antequera, Spain
Adria Coral 680 SP
just get a 12v charger for the laptop about £20
My high spec Dell laptop requires a 19.5volt 130 watt power supply. I asked advice from the techies at Dell and was told not to use 12v chargers. They recommended the pure sine wave inverter.
11,953
16,570
No. 12v can be taken from the link between the batteries meaning only one of them is used to supply 12v. It's an old wagon drivers trick to run 12v CB radios in their trucks. And it really doesn't work long term because it unbalances the load on the batteries causing early failure of the one used to supply 12v. For @mitzimad s racing car use imbalance is irrelevant because of the way they'd be maintained and charged.
This sort of discussion simply generates lots of posts and lots of confusion. The simple (and correct) answer is that 24v inverters (or any 24v equipment) can only be used on vehicles with 24v electrics. 12v inverters (or any 12v equipment) can only be used on vehicles with 12v electrics. If there is a particular need to operate equipment from a supply that is outside its design voltage range there are DC-DC converters available.
