£15k budget for a motorhome/van. Damp problems (1 Viewer)
Fulltiming Felines
176
50
My girlfriend and I want to move into a motorhome/van full-time. We've got about £15k budget but want to spend less if possible.
We've found two motorhomes we liked and paid MACIC to do an inspection on each. Both inspections advised not purchasing due to damp and other issues. Details from the reports below:
Motorhome 1
1988 reg. £6000
Various faults were found as listed above. The interior has been mostly and recently painted
with a very hard gloss paint. The reason for this is unknown but it makes it almost impossible to
obtain accurate damp readings, so you must draw your own conclusions as to why this has
been done. Furthermore, it is unsightly and devalues the Motorhome. No appliances could be
checked due to no power in the rear etc although after 15 minutes of engine running the
extractor fan worked but that was all.
It was disappointing that no service history was seen so it must be presumed that it has not
been serviced in accordance with the manufacturer’s schedules which may increase wear to
certain components. No cam belt record was seen so it must be presumed that this has not
been changed. There is an oil leakage which should be investigated further.
I cannot recommend the purchase of this Motorhome.
Motorhome 2
1990 reg. £8000
Essential repairs
Not recommended for purchase until following issues are rectified:
1. Delamination of floor under footstep and Nearside rear corner. Repair and cause to be
identified/rectified
2. Various areas of damp internally to be further investigated and repaired. Please see
report for damp readings and recommendations
3. Cracks in front corners of roof to be repaired
4. Offside tyre to be replaced and wear reason investigated
5. Nearside front window (remove misting to aid drivers vision)
6. Remove padding from front vents to aid demisting.
35% Off side above front window
35% in Off side rear overhead locker
29% in cupboard
27% around entrance door
15% in shower area
Guidelines for damp are as follows:
• 0-15% no cause for concern
• 15-20% require further investigation
• 20%+ remedial repairs required.
• 30% and above structural damage may be occurring and deterioration is
inevitable
We're feeling frustrated about this buying process now, having spent £800 on 2 inspections (£400 each). What should we do? Go ahead and buy one of these motorhomes and spend the money to fix them up? Or do more searching, possibly raising our budget, and try to find another vehicle that can pass inspection?
If we had to choose between these two, we're leaning towards Motorhome 2, as it has a lot of nice features like good sized fridge, lots of solar, automatic transmission.
Northernraider
27,380
176,892
On the sofa ....
Mobilvetta eurayacht
On and off since 95
Looking at this Hymer from a dealer in Germany. 1990. 114,642 miles. Does this look like a tolerable amount of rust on the underside?
Good idea. I messaged them yesterday but haven't heard back. They might have sold it offline or reached a deal and closed the auction early.
Couple of uk winters with salty roads and if that underside hasn t been cleaned up and painted it's gonna get serious.
Northernraider
27,380
176,892
On the sofa ....
On and off since 95
Here's a different Hymer: 1995, 90k miles. How's the rust on this one?
MOT is pretty clean, just the last two years have these advisories:
Nearside Rear Rear wheel bearing has slight play (2.6.2)
Offside Rear Rear wheel bearing has slight play (2.6.2)
How much does that cost to fix? I found this thread on Out&About. Sounds like it should be fixed before it gets worse, and might cost around £500 for both wheels. Does that sound right?
This one looks better ...still wouldn't hurt to have the spring hangers rubbed down and given a coat of hammerite
Wheel bearings shouldn't cost anywhere near £500
Northernraider
27,380
176,892
On the sofa ....
On and off since 95
But personally if it was my money and I was set on a u shape lounge I'd buy that mobilvetta.
The u shape lounge makes up to a bed in less than 5 minutes .
And you won't bang your head in that
D
deleted-member02
The Mobilvetta looks perfect for fulltiming on a budget. Loads of living space, good base vehicle and sensibly priced.
Of course it could be a shed but seems to be 'worth a look' based on the eBay advert.
Fulltiming Felines
Fulltiming Felines
176
50
Unfortunately it's been sold
138go
3,276
14,613
Carthago 138
Since 2001
Aaaaarrrrrghhhh :eek: ... I'm gonna shoot myself now :Eeek:... I can't take it anymore! :tmi:
Its worse than water torture! :crying:
Think I am going to have to agree with you. I am still trying to work out what the OP actually wants. We are now into discussing pictures of the underside of MHs .. What about the engine / gearbox , tyres ,gas installation , fridge etc and where is he going to put all his stuff.
We saw a great cartoon on an old Hymer the other day. It said “ You think this is slow wait till we get to a hill “ . The guy reconned it easily did 50 going down hill but struggled up the inclines.
9,189
47,489
Hurstpierpoint. Mid Sussex.
Compass Navigator
Ever since lighting was by Calor gas.
Indeed so. Buying any 20 yr old vehicle is a gamble. I've been buying, selling and restoring old and classic vehicles......MG's, Minis, motorbikes etc as a hobby/passion for 40 years but a m/h has far more to go wrong.........go wrong..........go wrong..........
Since the OP doesn't have the experience or 'feel' to identify and diagnose the relevance/seriousness of noises, corrosion, faulty brakes, steering, suspension..........he's a soft touch, so needs to buy from a reputable U.K. dealer (do reputable dealers have m/h's for just 10 grand??) or a very honest private seller who is selling his/her own m/h that has been owned, used and regularly serviced for a few years. Even then, with a say, 20 yr old 10 grand m/h he needs to put aside funds (a 2 or 3 grand slush fund?) to be able to get it right or even to pay for routine maintenance and replacement of consumable parts, especially full-timing. This summer my son paid £225 to have his 4 yr old caravan fridge repaired. (I don't do fridges).
Hopefully this thread has at least made the OP a little wiser.
mfw
Banned
Sep 16, 2017
1,224
508
Worthing
New mot rules should take a few neglected vehicles off the road anyway but anything with an mot until may will of been done under old mot guidelines.
My mot is not due until may next year and was done under old system.
Worst case it will always be worth something as scrap
Fulltiming Felines
Fulltiming Felines
176
50
My current thinking based on what you've all have said is that the two main dealbreakers are damp and rust. So I've been asking for the sellers to show me photos and do a damp check before I go view them. Of course I'll double check damp and rust and more when I actually do the viewing.
Yes, we've planned to have such a slush fund.
Peter Waller
70
48
Weston Super Mare
Hobby 750 fsme
1 year
I purchased my Hobby 750 fsme for £22,000 and its a 2001 with 30,000 miles and had lots of extras fitted for off grid living. I have recently discovered damp problems from a leaking shower tray that has spread about a bit in the under floor and some also by the inboard water tank. But there is nothing that cant be fixed if you have the right van that you love and want to keep! And I am very pleased with mine having already done 4000 miles since purchasing 10 months ago...its brilliant! So dont give up especially if you are prepared to do some work on it your selves.
Fulltiming Felines
Fulltiming Felines
176
50
Just viewed this today: Hymer B534, 1991, 140k miles
Photo album
I checked it all over for damp and didn't find anything over 10%, except the carpet around the fridge, which was reading up to 25%. But I pulled up the carpet and checked the floor, it only read 15%. But I wasn't able to pull up the the carpet in front of the fridge, only on the side.
What could be causing moisture to be accumulating around the fridge? Should I be worried about this?
7,228
20,071
Barnard Castle, UK
Concorde Concerto
Leaks from the fridge, happens a lot, check the floor area and try to get carpet up, it will need replacing anyway more than likely.
Have you been under the floor of the van from outside?
Fulltiming Felines
Fulltiming Felines
176
50
Yeah, the "photo album" link has photos of the underside. I didn't touch anything from the outside though.
Yes, the carpet and upholstery are all pretty old and I'd probably replace them after a few months, after we've "broken in" the moho for a few months. But they're certainly tolerable.
How to fix the leaks from the fridge?
maz
Jan 26, 2011
4,460
7,737
Bizeljsko, Slovenia
N+B Arto
Since March 2011
Great to know that you are still in love with your Hobby 750 even after the problems you’ve had with it. I used to have a later version - Toskana 750 FLC - best layout ever! (y)
Fulltiming Felines
Fulltiming Felines
176
50
Photo album
I'm buying this! Seller is going to drive it to me on Tuesday in Nuremberg where I'm staying with some friends.
I'll post some photos soon.
Katja
10
6
Germany
Conversion: Fiat Ducato
Newbie
Congrats! Hope you have lots of fun with your new home on wheels :). Would you mind opening a new thread about travelling/fulltiming in a moho with cats? I have a dog and 2 cats myself and would never have thought about taking the cats, as I figure they would have to be caged most of the time which they would hate. Therefore, I am very interested to hear if and how it can be managed.
Cheers!
Kat
Fulltiming Felines
Fulltiming Felines
176
50
Yes, will do so soon. We'll also blog about it.
For now, we have an Instagram: @fulltimingfelines
Katja
10
6
Germany
Newbie
Lovely cats :)! The kitties look quite content. Are the allowed to run free in the m/h while you are drinving?
Minxy
32,623
66,459
E Yorks
Carthago Compactline
It could simply be that when they turned the fridge off they don't put something in to catch the melting water from the freezer compartment so it has run out of the bottom of the fridge into the carpet ...
